Activity Forums Adobe Premiere Pro i7 2600 on premiere pro
  • i7 2600 on premiere pro
    Posted by Parthibaraj Rajasekar on February 2, 2017 at 6:01 pm
    How good is the performance of i7 2600 in premiere pro? I am going to use it as a starter. Will upgrade within a year or 6 months… Just wanted to know will it fair for a beginner?
    Motherboard supports 16 gb Max. Will upgrade the graphics cards to GTX 1070 /1060.
    Jan Janowski replied 9 years, 7 months ago 4 Members · 4 Replies
  • Jon Doughtie
    February 2, 2017 at 8:52 pm
    Your storage will also play a big role in this, as well as what footage you will typically be cutting. A m’board by itself is just not enough to give you any really significant feedback.
    System:
    Dell Precision T7600 (x2)
    Win 7 64-bit
    32GB RAM
    Adobe CC 2015.02 (as of 6/2016)
    256GB SSD system drive
    4 internal media drives RAID 5
    Typically cutting short form from HD MP4 and P2 MXF.
  • Parthibaraj Rajasekar
    February 3, 2017 at 5:35 am
    storage will go for a SSD and 2-3 TB HDD.
    I guess it supports only one SSD, should I boot OS in it or used the ssd as scratch disk?
  • Jeff Pulera
    February 3, 2017 at 3:46 pm
    Until a few months ago, I was still using the i7-2600 processor with Premiere CC. I could edit HD easily, like AVCHD or ProRes. I could also cut Sony 4K XAVC-S footage, surprisingly! Of course adding any effects would then slow that down right away, but I could play it well enough. I had a GTX 470 display card, system was over 5 years old.
    SSD is good for boot, and use 7200rpm SATA drives for storage, as they provide large capacity and low price. If you can add TWO of those drives, and configure as RAID 0 (stripe set in Windows) this will double the performance. If your system has USB 3.0, you could look at external storage. There are desktop drives (and RAIDs) meant for video editing, such as those from G-Tech, Glyph, and LaCie. The benefit of external is ease of moving to new system, just plug it in!
    Jeff Pulera
    Safe Harbor Computers
  • Jan Janowski
    February 4, 2017 at 4:22 pm
    Using an I7 2630QM processor with CS6… Dell XPS 702x laptop. Very happy with the results… compared to dual Core laptop that preceded it…. which even with Ram and CPU upgrade was very tired… Home/Hobby use here –1080i is max resolution.
    P.S. Though I’m not a fan of this… I did edit the GeForce 555M into Cuda list, and I was very much impressed with the results… Have not (Yet) been able to break it!!! :)!
    Looking for 1939 Indian Motocycle
