Activity Forums Adobe Premiere Pro I want to nest all my dialogue audio and add a compression filter in Premiere (not in Audition)
  • Paul Neumann
    June 12, 2014 at 1:40 am
    So many ways to do this:
    Nest the current sequence itself, drag it to the source monitor, drag the audio only into the sequence you originally nested from, add compression effect.
    Output your audio only and make a new sequence from the new clip, add effect, bring this sequence into your original.
    Set your compression effect on one clip. Save settings as a preset or just highlight and copy the effect in the effects panel. Select all the other clips and apply the same effect to all of them by dragging the preset on one of them or just hit ctrl v and paste the effect into all the highlighted clips.
  • Mark Landman
    June 12, 2014 at 3:52 pm
    You could use the audio track mixer in Premiere. Add an Audio Submix track to your sequence, route all of your dialogue tracks to the submix and add the appropriate dynamics or compression filter to the submix.
    Mark Landman
    PM Productions
    Champaign, IL
