Activity Forums Adobe After Effects I want to key better.
  • Ben G unguren
    September 29, 2011 at 8:20 pm
    You should be able to pull a good key with either of those, IMO. In general having dedicated illumination for the green wall/fabric helps, as long as you’re not overexposing. Higher-end keying facilities will use green lights on the wall (using gel might create a similar effect) which send some additional green light bouncing off the green surface.
    Have you tried this with a person or object in front of it? That’s really where the rubber meets the road, especially when you consider that you need to add lights for the subject, etc….
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Barry Bishop
    September 29, 2011 at 10:27 pm
    I do about 10 chromakey videos a month using this setup. It works good…but as I said I want to be better!
    I had a spare gel lying around and saw the [G] (green) shoot way up on the scope….so I’m purchasing gels now. I just want to be able to have a better key.
    Barry
    Associate Web Producer/ Video Editor
