Activity › Forums › Adobe After Effects › I want to hold a frame for about 5 sec,what should I do
Posted by Max on October 26, 2005 at 4:54 pmThx
Max replied 20 years, 11 months ago 3 Members · 3 Replies -
Yussef Cole
October 26, 2005 at 5:30 pmIf it’s a video clip enable time remapping in the layer menu and set two identical time keyframes 5 seconds apart from eachother.
If it’s something you’er animating in After Effects just set two identical keyframes for whatever value you’re animating 5 seconds apart from eachother. Or if you want to stop the motion of several things, precompose the layers and use the video clip method.
Yussef
Steve Roberts
October 26, 2005 at 5:32 pm[Yussef] “If it’s something you’er animating in After Effects just set two identical keyframes for whatever value you’re animating 5 seconds apart from eachother.”
… remembering to set the first keyframe as a “hold” keyframe.
Steve
