Activity Forums Adobe After Effects I WANT the 3d objects to composite based on layer order
  • I WANT the 3d objects to composite based on layer order
    Posted by Robert Paynter on May 4, 2010 at 11:11 pm
    I have a comp with many many layers. They are all 3d. I am animating them undulating (rotation and z position). I want them to composite like 2d layers, meaning visibility is determined by layer order. I know I could precomp each one. But it’s a lot of layers and I would like to maintain some control without digging down into each precomp. Is there a way to do this? or is this a dumb question?
    I’ve seen some posts on this as a problem or bug, but I haven’t been able to recreate it
    Todd Kopriva replied 16 years, 4 months ago 4 Members · 6 Replies
  • Bruce Wainer
    May 4, 2010 at 11:52 pm
    it’s a lot of work, but if you put a 2D layer between each 3D layer, it will work the way you want. A blank adjustment layer works best.
  • Tudor “ted” jelescu
    May 5, 2010 at 8:32 am
    1- in 3d space you need to make sure that the layers are in the same order in z space as they are as layers in the comp
    2- if you have done that, and you still experience problems, make sure you do not have layer styles on your layers ( if you imported them from a photoshop file with styles). One other thing that causes AE to mess up you 3d layers is if you have a 2d layer in between.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
    http://www.ennstudio.ro
  • Robert Paynter
    May 5, 2010 at 2:16 pm
    I have put adjustment layers between each of the layers. It is still not working. Not sure what I’m doing wrong,
  • Robert Paynter
    May 5, 2010 at 2:27 pm
    Ahha it worked. Have to be looking through camera not front view.
    May 5, 2010 at 2:54 pm
    Glad it worked- just be careful, adjustment layers are 2d layers, and mixing up 2d and 3d layers does not make AE very happy.
    Tudor “Ted” Jelescu
    Senior VFX Artist
    Bucharest, Romania
  • Todd Kopriva
    May 5, 2010 at 4:19 pm
    Here’s a page that explains all of the relevant details:
    “3D layer interactions, render order, and collapsed transformations”
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
