Activity Forums Adobe After Effects Expressions I want Adjustment Layer to only effects certian layers?
  • I want Adjustment Layer to only effects certian layers?
    Posted by Josh Johnson on February 10, 2009 at 8:19 pm
    Is this possible the achieve this set up with expressions?
    1. Adjustment Layer – Effect A
    2. solid1 – Effected A
    3. solid2 – Effected A
    4. Adjustment Layer – Stop Effect A
    5. Adjustment Layer – Effect B
    6. solid3 – Effected B
    7. solid4 – Effected B
    I am in a situation where I can’t precomp because I need everything to be visible from one comp.
    If it is possible can anyone point my brain in a direction get to get this achieved.
    Thanks for looking.
    Josh
    Josh Johnson replied 17 years, 6 months ago 2 Members · 2 Replies
  • Kevin Camp
    February 10, 2009 at 9:41 pm
    if layers 2 & 3 have transparency, you may be able to use the set matte effect to composite the transparencies of layers 2 & 3 onto a layer that you can then use as a track matte for adjustment layer 1. you’ll only be able to do this if layers 2 & 3 have not had any adjustments made to their layer transform properties (scale, rotation, position, etc) due to the limitations of the set matte effect….
    if you think you can work with those limitations, try creating a new layer (comp sized). add the set matte effect choosing layer 2 to take the matte from, check invert matte and uncheck composite with original. add the set matte effect again, this time take matte from layer 3, check invert matte and composite with original (in this case it will composite this matte with the first matte). now use this layer as a trakc matte (alpha inverted option) for your adjustment layer.
    the adjustment layer should only effect that area of the track matte which is now defined by the alphas of layers 2 & 3. of course there are effects that may not work like this… time effects like widetime or time blend may or may not work.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Josh Johnson
    February 10, 2009 at 9:49 pm
    I do need to use the position properties on the solid layers to achieve my effect.
    I am using the alpha channel from another comp on the adjustment layers to hide and reveal my solids. Putting the channel effect on the layer will not work correctly when I adjust the position of my solids.
    I could achieve this by creating multiple track mats, however I was hoping to create a cleaner solution.
    This is what my comp does …
    (A) < when object A moves down the line wipes it away >
    (B) < when object B move up the line wipes it away >
    It’s looking like a “pre-comp” expression isn’t possible.
    Thanks for looking.
