Activity Forums Adobe After Effects Expressions I wanna make a script, what now?
  • I wanna make a script, what now?
    Posted by Corbin Gross on August 5, 2008 at 8:35 pm
    So I don’t know a thing about scripts.
    I have a few things I use in all the videos I’m making right now. A circle shape layer with a popup expression, a solid with a path and stroke effect, and a text layer with an animator. I use them as callouts for some informational videos I’m making.
    I’d like to set up something to automate this set of layers so I don’t have to build them each time. I can modify them from some sort of generic form by moving the circle, path points and retyping the text, but I’d love to find a quicker way to make them.
    I was sent here from the AE Basics forum. What do you think guys?
    I’m on an Intel Mac with CS3
    Rhett Robinson replied 18 years ago 4 Members · 4 Replies
  • Dan Ebberts
    August 5, 2008 at 9:54 pm
    It sounds like a pretty ambitious first scripting project, but everything you want to do is doable. Working with shape layers is a little tricky, and you sort of have to create your own documentation, but again, doable.
    Dive in – holler if you get stuck.
    Dan
  • Patrick Hearn
    August 6, 2008 at 1:36 pm
    Best off googling scripting in After Effects and having a look at some resources. Read the adobe documentation probably and make a start on it then post here if you’re stuck on any particular part.
  • Corbin Gross
    August 6, 2008 at 2:21 pm
    Sounds like a good idea. I’ll start there.
  • Rhett Robinson
    August 7, 2008 at 5:58 pm
    https://www.aenhancers.com/
    is a great place to start… they’ve got a lot to pull apart here.
