Activity Forums Avid Media Composer I upgraded to 6.0.1 and I’m missing tools!
  • I upgraded to 6.0.1 and I’m missing tools!
    Posted by Matt Walker on April 17, 2012 at 7:31 am
    Hi all,
    I am using 6.0.1.
    When I go to Windows>Workspaces>Color Correction my Color correction tool in nowhere to be found!
    My final is due Friday!
    I’m using a Mac Pro 2×2.4 quad cores
    48 Gb ram
    running lion 10.7.3
    Matt Walker replied 14 years, 4 months ago 2 Members · 2 Replies
  • Michael Hancock
    April 17, 2012 at 2:14 pm
    How many monitors do you have and how are they set up? I had the same issue – this is how I solved it.
    If you have two monitors and monitor 1 is on the right, go to your System Preferences –>Displays–>Arrangement and make sure the menu bar (or whatever it’s called) is on the left monitor. Mine was on the right. When I swapped my monitors so it was on the left my Color Correction workspace showed up. See pic below:
    Michael Hancock
    Editor
  • Matt Walker
    April 17, 2012 at 3:51 pm
    I do have two monitors. I tried the switch, while avid was running and while it was closed, no luck. I just tried a clean reinstall too, nothing.
