Activity › Forums › Adobe After Effects › i told 2 friends and the told 2 friends
  • i told 2 friends and the told 2 friends
    Posted by David Tannenbaum on September 14, 2009 at 10:15 pm
    Ok this is a language issue: I am looking for the effect that I am sure is built into AE. It’s the effect that is right from the Breck shampoo ad from 30 or so years ago where the woman says I told 2 friends and they told two friends and so on and so on all the time the image divides and divides and divides until there are many many duplications of the same image.
    I’ve tried using the words “tile” “echo” “multiple” “repeat”
    What’s the effect called?
    thanks
    David
    Kevin Camp replied 17 years ago 3 Members · 2 Replies
  • Stuart Elith
    September 15, 2009 at 2:52 am
    Sure there is 🙂
    Motion Tile will do what you are looking for… it takes a source layer and gives you options to scale the original source and/or expand the output. A combination of the two with good timing will allow you to make it look like the camera is panning out or splitting.
    Note that it is using the ONE piece of footage, so if you wanted it to be lots of different people at once, you’d need to do it very differently.
  • Kevin Camp
    September 15, 2009 at 4:14 pm
    yep, motion tile (cc repetile would do it too, but motion tile would be slightly easier for this one).
    you can add a little expression to the tile width & height to link it to scale so that it easily replicates itself as you animate the scale. the expression would be like this:
    for width:
    100/transform.scale[0]*100
    for height:
    100/transform.scale[1]*100
    if you get really small for the scale, you may end up with an error like “unable to create layer size xxxx by yyyyy”. you can work around that by adding the transform effect above the motion tile effect, then link the tile width/height to the scale property in the transform effect and animate that scale property (rather than the actual layer scale property).
    the expression for width & height would then look like this if you had ‘uniform scale’ on:
    value/effect(“Transform”)(“Scale Height”)*100
    this method does add a slight edge between the tiles, but it will get you around the maximum layer size issue.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
