Activity Forums Apple Motion I this normal for HDV/Motion
  • I this normal for HDV/Motion
    Posted by Gregory Leno on March 30, 2006 at 12:35 am
    I am a Motion newbie and am tring to get a feel for what is to be expected from this program.
    When I bring in a 90sec clip and just try to play it back, before doing anything to it, it will only play back at 6-10fps. I have read here on previous posts that Motion can be slow, but is this true without doing anything to it? (see system config below)
    The clip plays back great on a FCS timeline.
    Is this just par for Motion or is there another explanation?
    Thanks for your help,
    Greg
    System=
    G5 dual 2.0 –
    3.5g Ram –
    nVidia 6800 Ultra 256vram
    160g internal hd –
    250g internal hd –
    Two 500g Lacie Big Disks via Firewire –
    20in Apple cinema display
    Noah Kadner replied 20 years, 5 months ago 2 Members · 6 Replies
  • Gregory Leno
    March 30, 2006 at 12:38 am
    Greg
    System=
    G5 dual 2.0 –
    3.5g Ram –
    160g internal hd –
    250g internal hd –
  • Noah Kadner
    March 30, 2006 at 3:57 am
    90 second is quite long for Motion- remember it works in RAM so you’re better off with much smaller chunks. Also you don’t have a super fast video card and HDV is a massive, massive processor hog. So there ya go.
    Noah
  • Gregory Leno
    March 30, 2006 at 5:59 am
    Given the Dual 2gig G5 that I am working on, is there a faster card that I can put in it. I was under the impression from previous posts that the nVidia 6800 was one of the fastest cards for my machine.(since I can’t install a pci express card.)
    At any rate, based previous posts I thought that Motion would at least play an unaltered HDV clip.
    See https://forums.creativecow.net/cgi-bin/new_read_post.cgi?forumid=170&postid=856396
    If I shorten the clip to 10 sec. it doesn’t seem to make a difference.
    Greg
  • Noah Kadner
    March 30, 2006 at 6:10 am
    Problem with HDV is that it is not a discrete frame codec that means that it must be actually decoded on the fly as it plays back so your performance will always be slower than with discrete frame codecs like DV and DVCPROHD. Plus the HD resolution also is a signifigant roadblock too.
    -Noah
  • Gregory Leno
    March 30, 2006 at 7:47 am
    Would I be better off converting to uncompressed and working from there?
    Greg
    System=
    G5 dual 2.0 –
    3.5g Ram –
    160g internal hd –
    250g internal hd –
  • Noah Kadner
    March 30, 2006 at 12:49 pm
    I’d suggest experimenting with different codecs. Uncompressed may work better then again it will also tax your hard drives with its much higher data rates.
    Noah
