Activity Forums VEGAS Pro I still can’t make text “zoom” either. Edward? Your earlier reply to another post?
  • I still can’t make text “zoom” either. Edward? Your earlier reply to another post?
    Posted by Graeme Hague on September 28, 2006 at 1:25 am
    There’s a posting earlier about this that Edward’s already answered, but I must be doing something wrong.
    I’m having the same problem making text “zoom” between a small, then larger, font size. Edward’s reply is fairly simple and straightforward- I understand. Yet I still can’t get a smooth, zooming-style transition between keyframes. The text just snaps to the new size when it hits the next keyframe. Is there a global setting that needs switching? It’s like the two keyframes need to be linked somehow.
    Cheers for any help.
    Graeme
    Graeme Hague
    Author/Composer
    Audio Engineer BREC
    Terry Esslinger replied 19 years, 12 months ago 4 Members · 4 Replies
  • Gary Kleiner
    September 28, 2006 at 1:36 am
    [Bag] ” The text just snaps to the new size when it hits the next keyframe.”
    Sounds like you have your keyframe interpolation set to ‘hold’. Right-click on the keyframe and set it to ‘linear’ or one of the others.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Edward Troxel
    September 28, 2006 at 3:06 am
    Make the text size the LARGE size. Now use “Pan/Crop” or “Track Motion” to resize the text. DO NOT use multiple keyframes in the text media generator and change the text between the keyframes.
    Edward Troxel
    JETDV Scripts
  • Graeme Hague
    September 28, 2006 at 4:09 am
    Thanks Edward, I figured this out eventually but the result was quite blurred… however, I’m guessing that’s because I didn’t have that LARGE size to begin with.
    The basic text tool does have scaling as well, which achieved something (the third party plug-ins don’t).
    However, you’ve basically answered my question- multiple keyframes in the text generator don’t do the trick.
    Thanks- thought I was going nuts.
    Cheers, Graeme.
    Graeme Hague
    Author/Composer
    Audio Engineer BREC
  • Terry Esslinger
    September 28, 2006 at 5:12 am
    Also, if you truly want a ‘linear’ zoom and not one that speeds up at the beginning and slows at the end you need to set the smoothness at 0 not 100.
