Activity › Forums › Avid Media Composer › I should have paid attention in math class.
Posted by Scott Davis on February 14, 2012 at 4:53 pmWe are shooting on the Nano Flash using XDCAM at 100Mbps. What is our per hour data usage?
Job Ter burg replied 14 years, 7 months ago 4 Members · 6 Replies -
Job Ter burg
February 14, 2012 at 5:18 pmAt what frame rate? 1080 would 48GB/hour, according to the Estimated Storage Requirements in the Avid manual (AVC-Intra 100).
Bouke Vahl
February 15, 2012 at 9:39 amWhat has framerate to do with it?
100 Mbits / sec is 100 / 8 = 12.5 MegaByte per second.
12.5 MB * 60 seconds = 750 MB per minute.
750 MB per minute makes 750 * 60 minutes = 45000 MB per hour.
45000 / 1024 = 44 GB/hour (excluding sound, as the datarate is normally specified for video only.)
Add about 400 Mbyte per channel per hour…Bouke
https://www.videotoolshed.com/
smart tools for video pros -
Chris Conlee
February 15, 2012 at 10:36 pmIn Job’s defense 😉 the Panny HVX200 says it shoots DVCPRO 100, which leads to the above-referenced formula, but if shooting the same codec at 23.976 720P native, you’re actually only using 80% of the datarate in the same amount of time. So yes, if the datarate is a locked 100Mb/s then the formula holds and framerate has nothing to do with it. However, if that’s the stated codec bandwidth, but you’re running at a different framerate that number could change depending on manufacturer, etc.
Chris
Job Ter burg
February 20, 2012 at 10:25 pm
