Activity › Forums › Adobe After Effects › I-pod commercial the next step
Posted by Jeff Bannister on October 21, 2006 at 3:46 amI love the Andrew Kramer i-pod tutorial, I just have to ask the next question. I dig that Particular attaches to a light as an emitter, but it still isn’t real 3d. I want the light to be able to go behind and in front of another layer. Any ideas…
Thanks for your help.
Jeff
Jeff Bannister replied 19 years, 11 months ago 6 Members · 7 Replies -
Julian Sixx
October 21, 2006 at 4:11 amHi
if your layer has got an alpha channel use the option “Obscuration Layer”,it’s under Visibility.
Unless you have an alpha channel use masks or even a luma matte might work,depends on your footage! -
Mylenium
October 21, 2006 at 7:51 amJust like julian said – use your keyed talent as an obscuration layer for Particular. Of course you need to properly adjust the path of Particular to avoid intersections…
Mylenium
[Pour Myl
Majorasshole
October 21, 2006 at 1:11 pmalso make a copy of layer that has your footage tuned to a black sillouette.
put the black sillouette below your footage layer
tint your footage layer so the higlights are the color of the lit ipod and trails.
add a soft edged mask to your footage layer and track its position to the ipod.
the mask should reveal a lit detail of your footage/talent in a soft edged circle where the mask is and a non lit looking silouette where the sillouette shows everywhere else. it should be a similar cheat to what they actually did with the lighting effect on the actual ipod ad.
Jeff Bannister
October 22, 2006 at 5:17 amThanks every one..I got it all figured out now….Looks good.
Jeff Bannister
Ari Grunzeweig
October 23, 2006 at 3:30 amHi,
I’m still confused…
In my comp, I have a few keyed still images all at the same z-depth.
I’d like to have my line weave around the keyed still images.
I tried to set one as my obscuration layer as one of my keyed images, but that blocked out the line even more.Where am I going wrong?
Ari -
Jeff Bannister
October 26, 2006 at 6:45 amTry placing the Obscuration layer under the particles in the timeline. That fixed my problems.
Jeff Bannister
