Activity Forums Apple Motion I only want to see the reflection, not the surface it’s reflecting on
  • I only want to see the reflection, not the surface it’s reflecting on
    Posted by Gareth Randall on January 14, 2015 at 3:17 pm
    I have some text over a background, and I want that text to have a blurry reflection. Easy enough to do by creating a “floor” for the text to reflect onto, but I only want to see the reflection, I don’t want to see the floor itself.
    Is there any way of doing this using the built-in reflections parameters, or do I just have to duplicate the text, flip it and blur it?
    Simon Ubsdell replied 11 years, 7 months ago 2 Members · 5 Replies
  • Simon Ubsdell
    January 14, 2015 at 9:42 pm
    Just make your floor black.
    If you need to kill the alpha channel of the floor (so that the reflection sits on a different background), set its Blending to Preserve Opacity.
    Here’s that in action:
    https://tokyo-uk.com/Motion/ReflectionOnly.zip
    Simon Ubsdell
    tokyo-uk.com
  • Gareth Randall
    January 15, 2015 at 6:52 am
    Thanks for that, Simon. I should probably have mentioned, my background isn’t black – it’s a full-frame gradient. Invariably, reflections tutorials use solid colour backgrounds, usually black.
    I’ve been able to get a reflection, albeit without the original colours, by using a black floor and setting its blend mode to Silhouette Luma. I’m assuming that if I wanted it in colour, I’d just have to duplicate and flip the text? The reflection can appear in colour dependent on the blend mode, but it doesn’t look quite right in any of them.
  • Simon Ubsdell
    January 15, 2015 at 9:08 am
    The trick there is to set the Blend Mode to Overlay and the Color of the floor to mid grey – which is not, as you might have thought 0.5/0.5/0.5 but rather 0.54/0.54/0.54.
    https://tokyo-uk.com/Motion/ReflectionOnly.002.zip
    That works – obviously you need to make sure that your Gradient BG layer is not casting reflections.
    Overlay with grey is a very useful trick to know about for this kind of thing.
    Hope that helps.
    Simon Ubsdell
    tokyo-uk.com
  • Gareth Randall
    January 15, 2015 at 12:21 pm
    Brilliant – thanks!
  • Simon Ubsdell
    January 15, 2015 at 3:35 pm
    I hope that helped. Just to clarify what’s happening with the Overlay Blend Mode in this scenario.
    Overlay uses a combination of the Screen on the lighter pixels, and Multiply on the darker pixels and applies each mode at half-strength, the result being that 50% gray values will be transparent.
    The Motion reflection however disregards the Blend Mode of the layer and will still be visible – note that it has its own Blend Mode option.
    Simon Ubsdell
    tokyo-uk.com
