Activity › Forums › VEGAS Pro › I. NEEED. Guidance. I’ve tried everything.
  • I. NEEED. Guidance. I’ve tried everything.
    Posted by Matthias Johannesson on December 30, 2013 at 11:25 pm
    Ho.. ly… Sh*t.
    I’m devastated. Completely smashed. Drained from energy.
    I’ve had one techincal issue after another and where I could fix the internet and my headset I JUST CAN’T seem to fix Sony Vegas Pro 12.
    Okay here we go:
    There is a lot going on here. Let me just address the issues at hand at first:
    1: When I render my files turns out darker than they originally are.
    1.a: When I try to use any kind of “lightening” effect to light it
    up it ruins my before great quality of 1080p HD. It makes it
    sort of grainy.
    2: This problems is kind of why I have problem number three. More or less unrelated to SVP12 however. I’ve begun doing LP and it’s actually going great and people have been really positive about my content. So, naturally, that motivates me to venture on.
    So. After just having finished Anna – Extended Edition, I decided to go for Shadow Warrior w/ facecam. I installed the game, turned FRAPS on, and were good to go. But. Hmm.. It seemed a bit laggy. Wow, actually very laggy. So laggy that I couldn’t play. So I went out and grabbed myself a copy of Dxtory. It had pretty good rumours, yes I had to do ALOT of reading to find out to use it but I made it work in the end.
    I record and it lags. A LOT. So after more researching I find out that I should download Lagarith Lossless Package (something like that I reckon). I do that. My game is super smooth. Finally! However:
    2.a: My Dxtory stops recording every 3,99 GB. I can find NO ONE
    with this problem. It doesn’t continue recording and use a
    different file like FRAPS, no, it just stops. Other people,
    as far as I understand, just get one long clip. Preferable,
    to having to press the record button to start and stop the
    recording every 2 min just to be sure that it does in fact
    record.
    3: Apparently. The only files (don’t know how it is for FRAPS) that Dxtory can record is rawcap and AVI. Rawcap is a tool (I think) so that you can make it into AVI later on and save recording/writing space. I suppose. Anyways, that leads me to AVI anyway which is cool. I can chose multiple sound channels. 1 for my microphone, and 1 for my in-game sound. (However I found that the sound could be better. So I found audacity. Anyone knows if I can record that when I play? Does it have a limited time of recording or something like that?). The real bugger here is:
    My. Sony. Vegas. HATES. DESPITES. AVI files. I’ve never, NEVER, seen so much lag in SVP. It’s ridiculous. I have to prerender everything if I just want a TINY change of being able to edit ANYTHING. Even when I do this, it tends (very often – very) to lag. Even after I used shift+b. What?!
    3.a: Nah-uh. I got more. When I render my videos (I used
    Videos4Youtube – an extension). It, even, lags in the rendered
    file.. Now the weird thing here is; that my webcam (as I told
    you, it was w/ facecam) does NOT lag. So I really assume that
    it’s something about these pesky AVI files.
    I’ve also tried rendering with something else than Videos4Youtube.
    I’ve tried EVERYTHING. I mean litteraly ANYTHING – except adressing the problem myself in the form of a forum. I’ve tried Google, YouTube, reading the SVP 12 manual, CreativeCOW, and other forums and more and more and more. I’m at the end of my road. I need some help.
    I will provide you with as much info as I can:
    Homemade PC:
    Windows edition:
    Windows 7 Ultimate
    Copyright 2009 Microsoft Corporation. All rights reserved.
    Service Pack 1.
    System:
    Rating: 5,9
    Processor: Intel(R) Core(TM) i5 CPU 750 @ 2,67 GHz
    Installed memory (RAM): 4,00 GB
    System type: 64-bit Operating System
    Pen and Touch: No Pen or Touch Input is available for this
    Display.
    Under Device Manager:
    Class for PdiPorts devices:
    – PDI Kernel Ports Device Driver
    Computer:
    – ACPI x64-based PC
    Disk drives:
    – Samsung HD154UI ATA Device
    – WD 10EADS External USB Device
    Display Adapters:
    – ATI Radeon HD 5800 Series
    DVD/CD-ROM drives:
    – TSSTcorp CDDVDW SH-S223C ATA Device
    Human Interface Devices:
    – Hid-compliant consumer control device
    – Hid-compliant device
    – USB Input Device
    – USB Input Device
    – USB Input Device
    – USB Input Device
    – USB Input Device
    – USB Input Device
    – USB Input Device
    IDE ATA/ATAPI controllers:
    – ATA Channel 0
    – ATA Channel 0
    – ATA Channel 0
    – ATA Channel 1
    – ATA Channel 1
    – ATA Channel 1
    – Intel(R) 5 Series/3400 Series Chipset Family 2 port Serial ATA Storage Controller – 3B26
    – Intel(R) 5 Series/3400 Series Chipset Family 4 port Serial ATA Storage Controller – 3B20
    – Standard Dual Channel PCI IDE Controller
    Imaging devices:
    – Logitech HD Pro Webcam C920
    Keyboards:
    -HID Keyboard Device
    Mice and other pointing devices:
    – HID-compliant mouse
    Monitors:
    – Acer P235H
    Network adapter:
    – Realtek PCIe GBE Family Controller
    – TP-LINK Wireless USB Adapter
    Ports (COM & LPT)
    – Communications Port (COM1)
    Processors:
    – Intel(R) Core(TM) i5 CPU 750 @ 2,67 GHz
    Razer Device:
    – Virtual HID Minidriver Collection
    Sound, video and game controllers:
    – AMD High Definition Audio Device
    – Avnex Virtual Audio Device
    – HD Pro Webcam C920
    – Turtle Beach SEVEN CHAT
    – Turtle Beach SEVEN GAME
    – VIA High Definition Audio
    System devices:
    – ACPI Fixed Feature Button
    – ATK0110 ACPI UTILITY
    – Composite Bus Enumerator
    – Direct memory access controller
    – High Definition Audio Controller
    – High precision event timer
    – Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 – 3B42
    – Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 5 – 3B4A
    – Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 6 – 3B4C
    – Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 7 – 3B4E
    – Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 8 – 3B50
    – Intel(R) 82801 PCI Bridge – 244E
    – Intel(R) 82802 Firmware Hub Device
    – Intel(R) P55 Express Chipset LPC Interface Controller – 3B02
    – Intel(R)processor DMI – D131
    – Intel(R)processor Miscellaneous Registers – D158
    – Intel(R)processor PCI Express Root Port 1 – D138
    – Intel(R)processor Semaphore and Scratchpad Registers – D156
    – Intel(R)processor System Control and Status Registers – D157
    – Intel(R)processor System Management Registers – D155
    – Intel(R) QuickPath Interconnect – D150
    – Intel(R) QuickPath Interconnect – D151
    – Microsoft ACPI-Compliant System
    – Microsoft System Management BIOS Driver
    – Microsoft Virtual Drive Enumerator Driver
    – Numeric data processor
    – PCI bus
    – Plug and Play Software Device Enumerator
    – Programmable interrupt controller
    – Remote Desktop Device Redirector Bus
    – Synaptics SMBus Driver
    – System CMOS/real time clock
    – System speaker
    – System timer
    – UMBus Enumerator
    – UMBus Root Bus Enumerator
    Universal Serial Bus Controllers:
    – Generic USB Hub
    – Generic USB Hub
    – Generic USB Hub
    – HUAWEI Mobile Connect – Bus Enumerate Device
    – Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller – 3B34
    – Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller – 3B3C
    – Logitech USB Camera (HD Pro Webcam C920)
    – USB Composite Device
    – USB Mass Storage Device
    – USB Root Hub
    – USB Root Hub
    That was everything from Device Manager. A lot could probably have been spared but as I said, I want to be sure.
    From the SVP 12 project:
    Properties for a random facecam video file:
    General
    Folder: C:UsersMatthiasVideosLogitech Webcam
    Type: Sony AVC
    Size: 376,34 MB (385.374.474 bytes)
    Created: 27. december 2013, 22:02:21
    Modified: 27. december 2013, 22:14:55
    Accessed: 27. december 2013, 22:02:21
    Attributes: Archive
    Streams
    Video: 00:12:33,184, 14,962 fps progressive, 1920x1080x12, AVC
    Audio: 00:12:33,433, 48.000 Hz; Mono, AAC
    ACID information
    ACID chunk: no
    Stretch chunk: no
    Stretch list: no
    Stretch info2: no
    Beat markers: no
    Detected beats: no
    Other metadata
    Regions/markers: no
    Command markers: no
    Media manager
    Media tags: no
    Plug-In
    Folder: C:Program FilesSonyVegas Pro 12.0FileIO Plug-Inscompoundplug
    Format: Sony AVC
    Version: Version 12.0 (Build 726) 64-bit
    Company: Sony Creative Software Inc.
    Properties for a random video file filmed with Dxtory:
    General
    Name: sw 2013-12-28 01-56-00-496.avi
    Folder: G:Movies
    Type: Video for Windows
    Size: 2,86 GB (2.930.208.784 bytes)
    Created: 28. december 2013, 01:56:00
    Modified: 28. december 2013, 01:58:36
    Accessed: 31. december 2013, 00:00:00
    Attributes: Archive
    Streams
    Video: 00:02:30,733, 30,000 fps, 1920x1080x32, Lagarith Lossless Codec
    Audio 1: 00:02:32,220, 48.000 Hz; 16 Bit; Stereo, Uncompressed
    Audio 2: 00:02:32,220, 48.000 Hz; 16 Bit; Stereo, Uncompressed
    Summary
    Software: DxtoryCore ver2.0.0.122
    Album/source: Video:Lagarith Lossless Codec Audio0:Speakers (Turtle Beach SEVEN GAME) Audio1:Microphone (Turtle Beach SEVEN CHAT)
    ACID information
    ACID chunk: no
    Stretch chunk: no
    Stretch list: no
    Stretch info2: no
    Beat markers: no
    Detected beats: no
    Other metadata
    Regions/markers: no
    Command markers: no
    Media manager
    Media tags: no
    Plug-In
    Folder: C:Program FilesSonyVegas Pro 12.0FileIO Plug-Insaviplug
    Format: Video for Windows
    My Project Properties:
    Video:
    Template:
    – Custom (1920×1080; 30,000 fps)
    Width:
    – 1.920
    Height:
    – 1080
    Field order:
    – None (progressive scan)
    Pixel aspect ratio:
    – 1,0000 (Square)
    Output rotation:
    – 0(degree sign) (original)
    Fram rate:
    – 30,000
    Stereoscopic 3D mode:
    – Off
    Pixel format:
    – 8-bit
    Compositing gamma (locked on):
    – 2,222 (Video)
    View Transform (locked on):
    – Off
    Full-resolution rendering quality:
    – Best
    Motion blur type:
    – Gaussian
    Deinterlace method:
    – Blend fields
    Adjust source media to better match project or render settings:
    – Checked
    Free storage in selected folder: 669,9 Gigabytes.
    Start all new projects with these settings:
    – Unchecked
    Audio:
    Master bus mode:
    – Stereo
    Number of stereo busses:
    – 0
    Sample rate (Hz:
    – 48.000
    Bit depth:
    – 16
    Resample and stretch quality:
    – Good
    Free storage space in selected folder:
    – 669,9 Gigabytes
    Ruler:
    Ruler time format:
    – Time & Frames
    Ruler start time:
    – 00:00:00,00
    Measures & Beats
    Beats per minute:
    – 120,000
    Beats per measure:
    – 4
    Note that gets one beat:
    – Quarter
    I don’t know what else I can provide you guys. Tell me – and I will.
    I REALLY hope that you can help me with this. Because I like editing videos and doing Let’s Plays, but not if I lag my ass out everytime.
    Thank you very much in advance,
    Fisenberg
    Dave Haynie replied 12 years, 8 months ago 3 Members · 5 Replies
  • Matthias Johannesson
    December 31, 2013 at 2:04 am
    Okay I dicussed this with a new-made friend on YouTube and it seems it’s my footage itself that’s laggy.
    Any suggestions to what I should do in the future?
    And any suggestions to what I can do to save what I got?
  • Norman Black
    December 31, 2013 at 4:47 am
    As for why your videos get darker, this is probably because your camera outputs full range data (0-255) and most players assume a smaller video range (16-235) by default (if they have an option). On playback the players expand the range back to 0-255 because this is what computer monitors want.
    Assuming your camera source is full range then…
    On the output video fx, you can add, Sony Levels with the Computer to Studio RGB preset.
    This will make the preview window in Vegas look a little washed out. I normally level the levels setting on and let it be washed out. Except of course when I am making color and contrast judgements.
    December 31, 2013 at 11:54 am
    Thanks for the tip!
    Is this the only way it’s done? Is there no alternative where I can preserve my quality and colours? 🙂
  • Norman Black
    January 1, 2014 at 12:55 am
    Yes, you have to make sure your levels are correct for correct playback. Rec 709 is the color standard for HD and in 8-bit digital form they specify that levels are to be 16-235. Full range is 0-255.
    Now it gets fuzzy and loose with “standards”. AVC (H.264) video stream support a flag which denotes if the contained data is full range. Many cameras output full range data and set this flag and the Vegas decoder handles this. They probably output full range because maybe you can adjust better before final output which might be 16-235.
    Some players/decoders may not look at this flag and assume a Rec 709 encoded file is 16-235. Here you will have a problem with playback if you have a full range file.
    Some editors like Premiere always normalize input to 16-235. Vegas does not. This gives access to the full camera range data but then puts the burden on you to get a proper range on output. Whatever that may be and whatever those requirements are.
    Also, I have no idea if the AVC encoders in Vegas support both full range and Studio (16-235) range or if they always assume 16-235. I have not tested.
    I just make sure my output will always be 16-235 and this means I have to add a levels adjustment to the output. Either Computer to Studio, or studio to computer depending on the situation. It is a pain, yes, and there are ways Vegas could add options to help us. It is what it is and we have to deal with.
  • Dave Haynie
    January 2, 2014 at 8:16 pm
    Lots of data presented there, but one big missing item: when you’re capturing video and hitting that 3.99GB limit… what device is it writing to? Writing uncompressed HD at 60p is not an exercise for the weak of heart… you would need about 380MB/s of sustained throughput to do that to a single drive in real time. You should check into the kind of compressed video available, and how that matches your HDDs.
    And if you’re writing to a 32-bit file system (eg, not NTFS or exFAT), you are pretty much getting some kind of error at 3.99GB… or perhaps just rolling over and over-writing the start of the file, depending on the software. You need a 64-bit file system. Assuming other users are not having this problem, that’s the thing to look for.
    -Dave
