Activity Forums Adobe After Effects I need your help
  • I need your help
    Posted by Nathan Trenkamp on May 31, 2006 at 7:44 pm
    Hi, simple question, but I can’t seem to figure it out. I’m trying to get my 3D layers to cast shadows by using light layers. I’ve enabled the cast shadow for both the light layer and the layer I want a shadow off of but still now shadow. What am I missing? Please help. Thanks a bunch.
    Sanspoof replied 20 years, 2 months ago 2 Members · 1 Reply
  • Sanspoof
    June 24, 2006 at 4:08 am
    Whelp, first make sure the layer you are casting the shadow onto is close enough and your light is aimed correctly (simple stuff but had to include it). Also make sure you’re not in wireframe in the monitor window.
    What about the color of the light you are casting… maybe that’s an issue?
    But for shadows to work you need to make all of your layers that you are casting shadows with into 3d layers and make sure all of their material options have accept and cast shadows turned on as needed. This and object allignment are most likely the problem unless there is some serious software/hardware problem.
    Maybe I helped a little.
    peace,
    Michael
