Activity › Forums › Apple Final Cut Pro Legacy › i need to know what’s the Technique?
Posted by Matta Roushdy on February 14, 2012 at 12:46 pmHello every Body I’m working as a senior Editor and motion graphic designer, i want ask about this song
I just ask on how to make this effect on the movement of the singer?
what’s the Technique and what is the software?https://www.youtube.com/watch?v=IOu0DuxFAT0&feature=relmfu
Thanks for Help
Matta Roushdy
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Adam Taylor replied 14 years, 6 months ago 8 Members · 13 Replies -
Adam Taylor
February 14, 2012 at 1:00 pmits called “stop frame animation” – its not software driven, its an in-camera effect created by shooting sequences of thousands of still frames, and moving slightly between each frame.
Thats how you get her clothing to be animated as well as her hair.
It also helps to photograph a pin sharp image on every frame without motion blur.To replicate a similar effect in video, i would remove every other frame, and then duplicate every frame that is remaining. Traditional animation is often done using “doubles” ie, for every frame they shoot two images, which is what gives the animation its staccato appearance.
Adam Taylor
Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
Character Options Ltd
Oldham, UKhttp://www.sculptedbliss.co.uk
My YouTube Animations Page -
Rafael Amador
February 14, 2012 at 1:29 pm[adam taylor] “To replicate a similar effect in video, i would remove every other frame, and then duplicate every frame that is remaining. Traditional animation is often done using “doubles” ie, for every frame they shoot two images, which is what gives the animation its staccato appearance.”
Yeap.
Speed up the footage 200%, then slow down to 50% without frame blending.
rafel -
David Eaks
February 14, 2012 at 2:04 pmHa Ha, static, bars and tone at the end. And it’s all Jelly Belly’s.
Is this done with multiple layers? In the beginning when she is walking past the trees, the foreground trees move by faster than the background trees as they would in real life. It seems like it would be quite time consuming to create that 3d effect without a separate layer for the tree going by. It looked like one layer to me…
Adam Taylor
February 14, 2012 at 2:05 pmwhoever said Art was fast?
Adam Taylor
David Eaks
February 14, 2012 at 2:14 pmThat’s not what I meant, I was thinking it’s pretty impressive to pull off. Painstakingly moving one by one in a single layer. I had fun watching it, so the artist did a good job…
I would be less impressed if it was layers.
Shane Ross
February 14, 2012 at 5:33 pmThis is straight up animation. Take a picture…move…take a picture…move…take a picture…move.
All done in camera on set. All practical.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Bret Williams
February 14, 2012 at 6:43 pmThere’s a link to the making of video when it’s finished. It’s a good watch. The first 20 seconds pretty much answers all the questions.
Bret Williams
February 14, 2012 at 6:49 pmThis is what the “strobe” effect is for. Just apply and it freezes every x frame for x frames. If it’s set to 4 for example, it plays frame 1 four times, then frame 5 four times, etc.
Richard Herd
February 14, 2012 at 7:43 pmIt is fast. You use multiple layers in After Effects (for example) and then place them in z-space and then move a camera right to left.
Mike Raff
February 14, 2012 at 8:31 pmWatch the “making of” video and you’ll see what’s involved:
22 months
1,357 hours
30 people
2 ladders
1 still camera
288,000 jelly beanshttps://www.youtube.com/watch?v=cIH4MJAC2Tg&feature=youtu.be
Mike Raff
Richmond, VASome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
