Activity Forums Avid Media Composer I need to create an Avid compatible EDL from Final Cut or Vegas
  • I need to create an Avid compatible EDL from Final Cut or Vegas
    Posted by Luis Artigas on May 20, 2009 at 2:47 pm
    Hi gurus
    I need to ceate an avid compatible edl from some other application. I have Premier cs3, Final Cut 5, and some version of Vegas in our facility. We need to supply another facility with an avid compatible edl. The edit is a 30 second promo that only uses clean cuts dissolves and a few rampings.
    Thank you in advance
    Luis Artigas
    AE Animator
    The Angostura Film Comapny
    Caracas Venezuela
    James Beattie replied 17 years ago 2 Members · 1 Reply
  • James Beattie
    May 20, 2009 at 3:54 pm
    You can select your sequence and export as a cmx3600. That will be able to be imported into an Avid system, using EDL manager.
