Activity › Forums › Adobe After Effects Expressions › I need to assign specific colors to specific characters in a text layer
Posted by Lauren Roundy on August 28, 2015 at 4:36 pmI have a wall of text that looks something like this: “ACGTGTCATCTAGACGT” only with TONS of different sequences like that for lines and lines and lines of text in a text box. I need the A’s to all be green, the C’s to all be blue, the T’s to all be yellow, and the G’s to all be red. Really, the actual colors don’t matter. I want to be able to change the color, but always keep the same letters matching with the same color.
Is there an expression that I can use that basically assigns a specific hex # or RGB value to specific characters within a long block of text?
I plan on copying and pasting different non-random strings of those same four letters into various parts of the project, but I always need the A’s to be green, etc…
Lauren
Ari Grunzeweig replied 7 years, 3 months ago 4 Members · 10 Replies -
Dan Ebberts
August 28, 2015 at 5:37 pmTry this.
Add a fill color animator.
Set the color to white.
Add an expression selector.
Add this expression to the Amount property of expression selector:
txt = text.sourceText;
switch(txt[textIndex-1]){
case "A":
color = [0,1,0];
break;
case "C":
color = [0,0,1];
break;
case "T":
color = [1,1,0];
break;
case "G":
color = [1,0,0];
break;
default:
color = [0,0,0];
break;
color*100
Dan
Lauren Roundy
August 28, 2015 at 6:09 pmWait, I changed my mind. I’m confused as to how to change the colors to any RGB value I want. What is the “color*100” line doing exactly?
Dan Ebberts
August 28, 2015 at 6:24 pmThe expression selector is expecting values between 0 and 100 for each color channel. I just used values between 0 and 1 for the arrays because expressions expect color channel values between 0 and 1, but I could just have easily done it this way for red:
color = [100,0,0]
and leave off the *100 at the end.
If you wanted to use values between 0 and 255, you could do it like this:
color = [255,0,0];
and have this at the end:
color*100/255
Dan
Lauren Roundy
August 28, 2015 at 6:26 pmAwesome, thanks! We figured it out a slightly different way, but it worked out. The thing that was confusing was that to make it work fully, the original text layer color has to be set to black. Ours was set to grey, so it was giving us less saturated colors than we wanted.
Thanks again for your help!
Dan Ebberts
August 28, 2015 at 6:31 pmAh yes, sorry–I forgot to mention that the text has to be black. Glad you got it worked out.
Dan
Lauren Roundy
August 28, 2015 at 6:43 pmTwo more things:
I tried it with and without the “color*100/255” and I’m getting the same result, which tells me that it isn’t necessary and is redundant code.
Second, I want to take this one step further and use a “master control” layer that has four fill effects (or some equivalent color effect with a color picker color option) and then use the pick whip to link the RGB arrays in the expression to the master control layer. This way, I can easily change, using the color eye drop picker in AE, the color that the expression is referencing without having to type in RGB numbers. How would this be accomplished?
You’re the best!
Dan Ebberts
August 28, 2015 at 6:52 pmLike this:
case "A":
color = thisComp.layer("master control").effect("Color Control 1")("Color");
break;
case "C":
color = thisComp.layer("master control").effect("Color Control 2")("Color");
break;
case "T":
color = thisComp.layer("master control").effect("Color Control 3")("Color");
break;
case "G":
color = thisComp.layer("master control").effect("Color Control 4")("Color");
break;
default:
color = [0,0,0,1];
break;
[color[0],color[1],color[2]]*100
Dan
Herman Van boeijen
August 15, 2018 at 9:29 pmHi everyone, I was looking for a script to color specific character sequences, and finally cobbled this together, which for me works on single instances of the color matches, and they work combined (I have three extra colors that certain text needs to have). This is for animating some videos for dyslexic children, and apparently coloring certain bits of text helps ☺
This works with plain “range selectors”.
//This set would set "foo", "bar", "do", "re" or"mi" to the desired color.
//Range selector START
wordsToHighlight = ["foo","bar","do","re","mi"];
amountOfWords = wordsToHighlight.length;
var txt = text.sourceText;
for(i = 0; i < amountOfWords; i++){
theword = wordsToHighlight[i];
if (txt.indexOf(theword) != -1){
txt.indexOf(theword);
break;
}//Range selector END
txt.indexOf(theword) + theword.length;
break;
Ari Grunzeweig
June 3, 2019 at 5:52 pmHi Dan and company,
I’m reviving this question. The expression is working great for me. I’m using the 255 variation.
However, even though I have the letter ‘a’ associated with a specific color value, different ‘a’s in my text and appearing as different colors.
Any ideas how to ensure each letter is always the same color?
Ari
