Activity › Forums › Apple Final Cut Pro › i need something to fix blown/washed out sky!
Posted by Shaun Gilmer on December 10, 2011 at 5:18 amI do media at my church now and I really need some filters/plugins that fix color, like a blown/washed out sky and other things. I love the Three Strip Technicolor and Captain’s Blowout Fixer ones on pistolerapost.com/pluginz/index.html but they wont work on X. Anyone know similar ones to those, hopefully free lol? Thanks
Simon Ubsdell replied 14 years, 7 months ago 4 Members · 6 Replies -
T. Payton
December 11, 2011 at 12:31 amNothing that I know of, but folks are making FCP X effects all the time. Perhaps now that you have suggested it someone could build it. The “Captain Blowout Fixer” seems like a simple filter to build in Motion. However, Motion 5 no longer has a Channel Swap filter, so it makes it a little difficult.
However, before you dive into the need for other filters, how familiar are you with the color correction in FCP X? If you are new to the app, I would recommend you check out Denver Riddle’s tutorials here:
https://www.colorgradingcentral.com/
Or you can watch them directly on Vimeo:
Perhaps you could post some examples of before/after of blowouts you have fixed in FCP 7 with these filters and we could recommend so ways to solve your issue.
T. Payton
OneCreative, AlbuquerqueSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Bill Davis
December 12, 2011 at 3:00 amJust so you realize that in digital video files, once the luminance value of a pixel gets set to 255 (full white) theres’ simply nothing there to “recover.”
If someone actually shot that sky as overexposed, the fanciest algorithm in the world won’t fix anything.
All it can do is to re-color pixels so that it “implies” a sky that wasn’t originally recorded.
Just how things work.
FWIW.
“Before speaking out ask yourself whether your words are true, whether they are respectful and whether they are needed in our civil discussions.”-Justice O’Connor
Simon Ubsdell
December 12, 2011 at 8:29 pm[Bill Davis] “Just so you realize that in digital video files, once the luminance value of a pixel gets set to 255 (full white) theres’ simply nothing there to “recover.””
But you’ve got more than one channel to play with (three in fact) and sometimes (often) there is more information in one or other of the channels that is less clipped than the others that can usefully be harnessed to restore detail. This is the way the very clever Captains’s Blow-out Fixer works – or used to. Once Apple give us back Channel Swap in Motion 5 (don’t know where it went to) it should be reasonably easy to make this kind of filter again.
Simon Ubsdell
Director/Editor/Writer
http://www.tokyo-uk.com -
Bill Davis
December 12, 2011 at 8:45 pmInteresting, Simon.
I would have thought that a fundamental issue like allowing too much light to hit the photo sensor would result in a “blow out” of the luminance data in all the channels – but if there is less luminance sensitivity in an individual color channel and data that can be re-claimed and used to recover pixel luminance states, that’s very useful to know.
Thanks for taking the time to mention it.
(learning is a life long task these days – thankfully!)
T. Payton
December 16, 2011 at 8:08 pmSaw these new plugins, some of them might be useful for highlight recovery:
https://www.irudis.com/Products/TonalizerVFX/DemoReel.aspx
https://www.crumplepop.com/?page_id=1539?source=idustrialrevolution
T. Payton
OneCreative, Albuquerque -
Simon Ubsdell
February 12, 2012 at 5:15 pmI’ve just posted a new free effect I’ve been meaning to make for a while that addresses this issue. It’s not quite the magic bullet that will fix anything (when it’s really gone, it’s really gone!) but hopefully you will be surprised at how much detail you can recover with it.
https://forums.creativecow.net/readpost/344/8067
Simon Ubsdell
