Activity Forums Cinematography I need some advice on camera
  • I need some advice on camera
    Posted by Senem Ocal on December 3, 2014 at 12:05 pm
    Hi all,
    im a documentary film maker for aljazeera for 7 years.
    Now, this year they changed their technical specification. From now on, they want 50/Mbps – 1080i 422 INTERLACED video.
    I generally used as master camera Panasonic AG-AF 101 with Atomos ninja blade which it can shoot 50 Mbps / 1080i.
    But, my secondary camera is 5D mark 2 and its no longer sufficent.
    So, i need to buy camera.
    Blackmagic cinema camera: it can shoot 50 mbps 422 but only progressive. It need external recorder for interlaced.
    Canon 5D Mark 2 also needs external recorder.
    Black Magic URSA is ok, but price is more then my budget.
    Im really confused.
    Could you please suggest me a good solution?
    Thank you all and sorry for my bad English 🙁
    Daniel Stone replied 11 years, 9 months ago 3 Members · 2 Replies
  • Bill Bruner
    December 7, 2014 at 2:19 pm
    Hi Senem – if you don’t mind going back to a small sensor camcorder, the old Canon XF100 records 50mbps 4:2:2 1080/50i in PAL areas and 50mbps 4:2:2 1080/60i in NTSC areas.
    You can get new PAL XF100 for £1708.50 on eBay UK.
    Or, if you need 1080/60i, you can get a new NTSC XF100 for $2499 from Amazon US.
    Hope that’s helpful and good luck!
    Bill
    Hybrid Camera Revolution
  • Daniel Stone
    December 8, 2014 at 12:23 am
    Are you delivering raw footage or a finished product? Those specs are typical for broadcast delivery and if you’re delivering a finished product you would convert to those specs at the end rather than filming in that format.
    We film and edit a lot of broadcast projects in 1080/24p (23.98) with 8-bit DLSRs (5D, FS100, etc) and deliver in 1080i, 422, 50Mbps (via DG FastChannel) with no problem.
