I need recommendation for real DVD
Posted by Jerry Waters on September 25, 2007 at 2:18 amI have encoded 3 times with Vegas as directed and with video 3.6Gb and 363mg audio DVDA says that adds to 6.1GB and reencodes. Please, someone recommend me a decent DVD program. I need a REAL program. Thanks.
Rob Mack replied 18 years, 12 months ago 8 Members · 11 Replies -
Edward Troxel
September 25, 2007 at 1:15 pmI don’t know why Vegas sometimes doubles the MPEG size. I just know it sometimes happens. Does the MPEG2 file also contain audio? Are you providing audio separately as well?
If yes, what if the MPEG2 does NOT contain audio and you provide it separately?
Not that you’d want to do this but what if the MPEG2 file does contain audio and you don’t provide it separately?
What if you just give DVD Architect an AVI file and let *IT* change to MPEG2 and AC3?
Terje A. bergesen
September 25, 2007 at 3:00 pmCan you just master DVD-9 (dual layer) where DVD-A should not re-encode, don’t burn a disk, just master to a folder. If that master is smaller than the size of a regular DVD, burn to DVD using NERO or even DVD-A by using “Burn a previously prepared folder”?
Sebastien Gravel
September 25, 2007 at 6:45 pmThe easiest way is to save from Vegas in DV-AVI and let DVD Architect do the encoding. I’ve never had any problems doig it this way.
Douglas Spotted eagle
September 25, 2007 at 6:54 pmThe easiest way is to save from Vegas in DV-AVI and let DVD Architect do the encoding. I’ve never had any problems doig it this way.
if you don’t mind losing quality, this is a fine method of working. The encoder in Architect is not as good as the fully featured encoder found in Vegas, not to mention the chroma loss starting with a DV-based master vs the timeline.
Douglas Spotted Eagle
VASST
Aerial Camera/Instructor
Certified Sony Vegas Trainer -
Sebastien Gravel
September 25, 2007 at 10:06 pmWhy would the encoder be different? Isn’t Sony shooting itself in the foot by doing that?
Also, the timeline is a DV-Avi file. Starting with version 8, you can work in 32 bits. So, there would be no quality loss from DV-Avi timeline to Dv-Avi Master. Of course, I could be wrong…
Warren R sampson
September 26, 2007 at 3:22 amI use Vegas along with the Cinema Craft Basic encoder and DVD-Lab Pro. DVD-Lab has many features in common with high end authoring packages. Not fancy looking, but very powerful.
DVD-A is not quite there yet, sadly.
https://www.cinemacraft.com/eng/basic.html $60
https://www.mediachance.com/dvdlab/dvdlabpro.html $249
Edward Troxel
September 26, 2007 at 12:34 pm -
Jerry Waters
September 26, 2007 at 7:46 pmSony says that the problem was I encoded 24 WITHOUT PULLDOWN. Supposedly, if you use pulldown it works but if not DVDA will reencode. Isn’t that strange with Sony and others making 24p cameras? DVDA is written for deinterlaced footage only?
That sounds like huge BS to me written by somebody who wrote the thing and doesn’t want to take responsibility to fixing it.
Edward Troxel
September 26, 2007 at 8:07 pm -
Mike Kujbida
September 26, 2007 at 10:03 pmJerry, I don’t remember you saying what camera you were using but Sony has two 24p whitepapers (PDF format) on their site aimed at 24p production in Vegas and DVDA.
One is 24p and Panasonic AG-DVX100 and AJ-SDX900 and the other is 24p HDCAM/DVCAM.I know that the DVX100/SDX900 paper has very specific steps for successfully burning a 24p DVD.
