Activity Forums Apple Final Cut Pro Legacy I need help with HDV deck and FCP
  • I need help with HDV deck and FCP
    Posted by Granted on October 6, 2006 at 6:46 am
    I am using a Sony HDV (HVR-M10U) deck and it is hooked up to FCP. I have hooked it up in the past and would just adjust the sequence/timeline/capture/deck settings to accompany the time of project I was conducting.
    Recently I unhooked the deck from my computer and when I rehooked it up it started being difficult. As of now it will not play back ANYTHING in the viewer or timeline. When I go to the A/V settings it claims that the Video Playback is: [Missing] Apple FireWire NTSC (720×480)…
    That happens when I am just trying to edit normal DV and it won’t even register when I try to edit HDV. I really need help figuring out what is wrong. I’m not sure what to do with the settings to fix this issue and it’s highly frustrating. I have tried everything from replacing the connection cable to going through the settings on the decks menu to FCP’s settings. PLEASE HELP ASAP!
    Best,
    Grant
    Thoward replied 19 years, 11 months ago 2 Members · 1 Reply
  • Thoward
    October 21, 2006 at 1:44 am
    I have the same problem with Sony’s HVR_ZIU camcorder. I can find settings in Audio/Video Settings that allow capture from the camera but playback output only allows None.
    I will let you know when I find a solution.
