Activity Forums Apple Final Cut Pro Legacy I NEED HELP ASAP
  • I NEED HELP ASAP
    Posted by Nevin on April 26, 2005 at 1:44 am
    I am trying to nest a 16:9 sequence into a 4:3 sequence, but the preset keeps defaulting back to anamorphic everytime i change it. So my 16:9 stuff is stretched out on a 4:3 screen but its set to anamorphic.
    The nesting has been working until now when i need it the most.
    Does anyone have any clue how to fix this?
    Nevin
    p.s. this is due tomorrow at 10 am!!
    Nevin replied 21 years, 4 months ago 3 Members · 3 Replies
  • Jason Lyons
    April 26, 2005 at 4:27 am
    Are you copying and pasting the clips of one sequence into the new 4:3 seq or or dragging the 16:9 sequence to the 4:3 sequence?
  • Joachim Freitag
    April 26, 2005 at 6:11 am
    what about the “aspect” control when you are working the clip in the viewer?
  • Nevin
    April 26, 2005 at 4:30 pm
    For some reason my animorphic sequences, although set to anamorphic, would stretch to fit the 4:3 superwhite setting rather than letterbox.
    I ended up figuring a laborious fix that got the job done. I just dropped the already 16:9 sequence into another 16:9 sequence and then dropped it into the 4:3.
    I only seemed to have this problem with animorphic sequences which incorporated still pictures. In other words all the native 16:9 shots would letterbox just fine if they were the only items in the sequence, but if I added a picture scan to the sequence the 16:9 sequence wouldnt letterbox when added to a 4:3 sequence.
    I assume that’s my problem, I just dont know why it was happening.
    All in all, at least I got my project finished.
    If anyone has any ideas or knowledge of why these sequences with pictures were acting this way, i’d appreciate your thoughts.
    Nevin
