Activity Forums Adobe After Effects I NEED H3LP-After effects transition effect
  • I NEED H3LP-After effects transition effect
    Posted by Roman Hudaj on November 20, 2016 at 9:41 pm
    I’ve been looking absolutely everywhere to learn how to do this technique but i cant find anything at all.
    SO, basically i want to merge two videos together. The two videos are taken on a tripod. The camera is turning horizontally until it a wall passes by. After it passes the wall i want it so that the next place shows up from behind the wall and it keeps on turning .Sort of like jumping from one place to the other. Or turning a corner and being in a completely different area,
    The best example i could come up with is this video———-https://www.youtube.com/watch?v=U7dkZLtdK2M
    If you skip to 0:53,
    this is basically the effect i’m looking for.
    PLEAS HELP, THANKYOU!
    Greg Gesch replied 9 years, 10 months ago 2 Members · 1 Reply
  • Greg Gesch
    November 21, 2016 at 10:40 pm
    Hi Roman, all you need do is draw a mask around the element you want to reveal the layer underneath. In your example the rear of the truck would be masked so as it passes the playground is seen.
