Activity Forums Apple Final Cut Pro Legacy I Need Color Correction and Effects Workflow Advice: FCP7 to After Effects
  • I Need Color Correction and Effects Workflow Advice: FCP7 to After Effects
    Posted by Jon Mitchell on November 19, 2013 at 3:27 pm
    I’m looking for some advice on workflow. I just finished a short film and now need to color correct and a few effects and animation shots. I figure my best bet will be to use Automatic Duck to import the project in AE (I’m using FCP7 and AE CS4 – so old school, right?). This way, I can color correct, add effects, create animation comps etc and work on it all right there.
    (And yes, I know FCP7 has a good color correcter, I like AE better).
    Is this the best workflow? Does anyone have any tips or suggestions? My project will end up being around 13 minutes long (1080 24p), the render time is going to be murder, isn’t it?
    Any thoughts on using Resolve or Color instead? Maybe creating my anim and effects shots and inserting them into FCP7 before going to color correction?
    Jon Mitchell replied 12 years, 9 months ago 3 Members · 3 Replies
  • Rafael Amador
    November 19, 2013 at 4:40 pm
    For color grading, Apple Color is better suited than AE.
    If your project was longer I would suggest Color; but being that short, if you feel comfortable with AE, go with it.
    rafael
  • Shane Ross
    November 19, 2013 at 5:38 pm
    Do you know how to use RESOLVE or COLOR? They aren’t simple apps. They have very specific workflows that need learning before you can use them. Use what you are comfortable with. I also recommend Red Giant’s COLORISTA 2 if you want to be simple and stick to grading in FCP. You can push things far more with it than you can the 3-way color corrector
    Shane
    Little Frog Post
  • Jon Mitchell
    November 19, 2013 at 5:44 pm
    Thanks for the input guys. I think I will just stick with what I know. Going to test run a round trip here in a second to see what limitations exist.
    Yeah, I was just watching a tutorial on Resolve. It looks amazing, but like the learning curve doesn’t correlate with my deadline. 😛
