Activity Forums Adobe Premiere Pro I need an audio meter!
  • I need an audio meter!
    Posted by Nick Patten on July 20, 2005 at 4:43 pm
    is there any kind of plugin or third party software that would allow for an on screen audio meter that will display levels while capturing into premire. I have the ablilty to adjust the levels of my DV stream by going through a TBC but i want an on screen display. any ideas would be helpful.
    David J replied 21 years, 1 month ago 3 Members · 2 Replies
  • Steven L. gotz
    July 20, 2005 at 6:20 pm
    Capturing DV from a MiniDV camera is just a file transfer. So no adjustment should be possible without converting to analog first. Why not just fix the audio in post?
    Steven
    Adobe Premiere Pro 1.5.1 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • David J
    July 20, 2005 at 10:44 pm
    As Steven says, FireWire capture from a DV source is just data transfer – no processing and no access to elements of the stream like there was with analogue.
    On the other hand, if your source is analogue and you are using a bridge to generate a FireWire input, then a readout of audio levels during capture could be very useful since you will be able to adjust audio levels in the analogue domain before its conversion to FireWire.
    If you need to watch audio levels during capture, then Scenalyzer Live has this facility. http://www.scenalyzer.com has a trial download which watermarks footage but is otherwise functional before you buy.
