Activity › Forums › DaVinci Resolve › I need advice on how to approach fixing this clip
Posted by Anthony Sneed on April 22, 2023 at 9:22 pmI have a clip that is an absolute nightmare, and I tried a few things but it’s not working.
The shot has so many value changes and even some weird tinting the jumps in and out.
How would you approach this? I’m okay with keyframing every frame if need be I’m just not sure what to do.
Shahid shahan replied 3 years, 5 months ago 4 Members · 5 Replies -
Shahid shahan
April 23, 2023 at 4:52 amBased on the information you provided, it sounds like the clip has a lot of variations in color and exposure, which can be challenging to fix. Here are a few approaches that you can try:
1. Use color grading tools: In DaVinci Resolve, you can use the color grading tools to adjust the exposure, contrast, and color of the clip. You can use the scopes to analyze the color values of the clip, and then adjust the color grading controls to bring the colors into balance. You may need to make adjustments to each individual shot or frame to get the best results.
2. Use automated color correction: If you don’t want to manually adjust each frame, you can use the automated color correction tools in DaVinci Resolve. You can try using the “Color Match” feature, which will analyze a reference clip and match the colors of your problem clip to the reference. You can also use the “Auto Color” feature, which will attempt to automatically adjust the colors of the clip based on the overall color balance.
3. Use keyframing to adjust exposure: If the exposure changes are the main issue, you can use keyframing to adjust the exposure of the clip frame-by-frame. You can add keyframes to the exposure controls and then adjust them to match the brightness and exposure of each individual frame.
4. Use a secondary color correction: If there are specific areas of the clip that have different color values or exposure, you can use the secondary color correction tools to adjust those specific areas. You can use the Power Windows to select the area that you want to adjust, and then use the color grading controls to make the necessary adjustments.
Andrew Shtern
April 23, 2023 at 7:54 amI’d leave alone the changes introduced by the lens flare and concentrate just on making the clip look good and consistent with the previous/next clips on the timeline.
Andrew Shtern
April 23, 2023 at 7:58 amBased on the information you provided, it sounds like you’re using Chat GPT to generate long and absolutely useless generic answers in different threads.
Riccardo Luppi
April 23, 2023 at 8:10 amHey Anthony,
Here are my two cents as a colourist: first of all I would not bother trying to “fix” the flare, both in contrast and colour shift. It is part of the shot and its beauty. I would probably park on a frame that has no flare con correct the shot based on that frame so that the flare naturally falls into place where it makes sense. Just check the flare frames from time to time to make sure nothing there is getting clipped or out of the gamut and you should be fine.
Best,
Riccardo -
Shahid shahan
April 23, 2023 at 8:28 amHey andrew
Yes, I had taken some help in this discussion using GPT. I apologize. For your problem is not fixed but you can watch my this video for better understanding.
Or if you are still confusing you can contact me here,
Thank you.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
