Activity Forums Adobe After Effects Expressions I must be busy this morning, continued!
  • I must be busy this morning, continued!
    Posted by Olly Bea on April 11, 2008 at 3:16 pm
    Hey
    Following from my earlier post (I must be busy this morning, 2 posts!) I would like to try and generate a new position each time opacity = 100 but hold in that position until opacity reaches 0.
    The current code I have in opacity:
    prop=thisComp.layer(“Bass 3”).effect(“Both Channels”)(“Slider”);
    threshold=5;
    fadeOut=1; // in seconds
    t=time;
    while (t>time-fadeOut) {
    if (prop.valueAtTime(t)>=threshold) {
    break;
    t-=thisComp.frameDuration;
    linear (time, t, t+fadeOut, 100, 0)
    Many thanks
    Olly
    Olly Bea replied 18 years, 4 months ago 2 Members · 2 Replies
  • Filip Vandueren
    April 11, 2008 at 4:00 pm
    a different approach this time, because now the expression has to scan from the beginning, and count how many times the threshold has been met.
    I referencing the original Audio data, instead of the opacity:
    prop=thisComp.layer("Bass 3").effect("Both Channels")("Slider");
    threshold=5;
    peaks=0;
    t=0
    while (t<=time) { if (prop.valueAtTime(t)>=threshold) {
    peaks++;
    t+=thisComp.frameDuration;
    seedRandom(peaks,timeless=true);
    random([0,0],[720,576]);
    This first counts the number of peaks from time 0 untill current time, then uses that number to find a random position between [0,0] and [720,576]
  • Olly Bea
    April 11, 2008 at 4:21 pm
    superb thanks very much!
