Activity Forums Adobe After Effects Expressions I must be busy this morning, 2 posts!
  • I must be busy this morning, 2 posts!
    Posted by Olly Bea on April 11, 2008 at 10:56 am
    Hi
    I have this expression for opacity:
    g = thisComp.layer(“Bass 3”).effect(“Both Channels”)(“Slider”);
    if (g<5 || g>5) 100 – time*20 else 0
    I am trying to get the layer’s opacity to turn on (100%) then fade out over 5 secs if the value from the audio (converted audio keyframes) is greater than 5. But if the value from the converted audio is less than 5, opacity stays at 0%. Does anyone know where I am going wrong?
    Thanks, Olly
    P.S. Sorry Bert Brown I tried that link and the code didn’t seem to work.
    Olly Bea replied 18 years, 4 months ago 2 Members · 2 Replies
  • Filip Vandueren
    April 11, 2008 at 1:37 pm
    Hi olly,
    The trouble with expressions is, they recalculate every frame, so the expression does not know that there was a peak a few frames ago.
    The solution is to actively look back at every frame for the last 5 seconds to see if there was a frame that peaked.
    This seems to work:
    prop=thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
    threshold=5;
    fadeOut=5; // in seconds
    t=time;
    while (t>time-fadeOut) {
    if (prop.valueAtTime(t)>=threshold) {
    break;
    t-=thisComp.frameDuration;
    linear (time, t, t+fadeOut, 100, 0)
  • Olly Bea
    April 11, 2008 at 2:26 pm
    that works brilliantly! Thanks loads
