Activity › Forums › VEGAS Pro › I m a complete total Vegas beginner : Why did Vegas make my .MOV files unreadable?
Posted by Remy Thirot on September 6, 2011 at 10:07 pmHi . I ve just installed Vegas and I was trying to see if it could read my .MOV files, then in the main video window I just tried to clear it so I selected “None” then after clicking File> New etc then closing vegas my .MOV file was unreadable then I have 4 files instead : the Unreadable .MOV file, a .sfk and a .sfl file, and a .jpg file, what the… ?
Dave Haynie replied 14 years, 12 months ago 6 Members · 12 Replies -
Stephen Mann
September 7, 2011 at 5:54 pmYour workflow confuses me. What version of Vegas and where is “none”?
Did you try opening Vegas then dragging the MOV file to the timeline?
Also, to edit MOV files you need to have Quicktime installed.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Frederic Baumann
September 7, 2011 at 8:03 pmI share Stephen’s confusion, but have two questions:
1) are you sure that your MOV file was working before using Vegas?
2) what did you use to view your MOV file, apart from Vegas?Frederic
Want to match colors between clips? new plug-in here.
Check FBmn Software plug-ins to fix white balance and exposure issues.Want to learn on Sony Vegas Event Pan/Crop tool? Watch my video tutorial:
https://library.creativecow.net/baumann_frederic/Sony-Vegas_event-pan-crop-tool/1
Or about Keyframes? https://library.creativecow.net/articles/baumann_frederic/Animating-with-Keyframes-in-Sony-Vegas.phpFrench version: https://geo.creativecow.net/fr/a/12999
Remy Thirot
September 7, 2011 at 11:53 pmHi, thanks for you answers.
I was able to read my .MOV files perfectly with Quicktime or even WMP before trying to drag then to Vegas. And yes I was able to move them to the timeline before it happened…
By the way I kept on working a little and I don t have the same problem with .AVI files, something really bugs me about that .MOV files thing, I tried with a meaningless .MOV file again to see if the same thing was going to happen and it did : moving it to the main window, not the preview one, something they call trimmer window or sth like that, and then selecting “None” instead of the file path above that window instantly creates a .SFK and a .SFL file wearing the .MOV file name, plus a .JPG file, and the .MOV still exists and becomes unreadable.
I’m using Vegas pro 10.0 by the way …Hoping that I was more clear this time 🙂
Remy -
Stephen Mann
September 8, 2011 at 12:58 amDon’t worry about the sfk and sfl files. Vegas uses these for waveform and other information.
I am really puzzled about the jpg file, though. You have to intentionally make a screen grab to get the jpg file.
MOV files, are by the way, notoriously difficult to edit. Many people find it better to transcode the MOV file into something easier to edit.
But I still don’t follow what you are doing. Open Vegas then drag the mov file to the timeline. What happens?
Steve Mann
Remy Thirot
September 8, 2011 at 1:02 amthe .MOV file became totally unreadable now, by Vegas or by quicktime or by everything. I can’t drag it to Vegas anymore
Stephen Mann
September 8, 2011 at 2:47 am[Remy Thirot] “I can’t drag it to Vegas anymore”
I still don’t follow what’s going on. What do you mean that you can’t drag the mov file? You mean that the icon is locked and won’t move?
Did you ever do a “render as” or “save as” using the same mov filename?
There’s something missing in your description of the problem because Vegas won’t do anything to your original media.
Steve Mann
Remy Thirot
September 8, 2011 at 2:57 amWell it s weird because it definitely did.
I can drag it but it now says that Vegas can’t read the file. It could before damaging it tho. -
Mike Kujbida
September 8, 2011 at 11:37 amI agree with Steve.
I’ve been using Vegas since it was version 1.0 and have NEVER had it damage a file.
p.s. it’s not a good idea to post this question in two different Vegas forums on here as a lot of folks read one but not the other. -
Stephen Mann
September 8, 2011 at 1:01 pmThe only way this could happen is if you did a “save as” to the same filename, and I don’t think that Vegas would even allow that.
Get the free utility “mediainfo” from: https://mediainfo.sourceforge.net/en
What does it say about the bad mov file?Can we start over with another mov file?
Steve Mann
Mike Kujbida
September 8, 2011 at 3:51 pmYou can upload up to a 2GB. file free through Dropbox (free as well) for us to download and see if it works for us.
https://www.dropbox.com/
