Activity Forums Adobe Premiere Pro I load video in but it does not play back. I can see the video but will not play.
  • I load video in but it does not play back. I can see the video but will not play.
    Posted by Mark Havens on September 8, 2009 at 7:32 pm
    Hello,
    I added a folder containing my video clips and everything looks normal, but when I click the play button nothing happens. I added the clip to the time line to see if the review work area would play the clip but nothing happens.
    Could I have imported the files wrong? Could it be as simple as a settings issue?
    Mark Havens replied 16 years, 12 months ago 2 Members · 2 Replies
  • Mike Velte
    September 9, 2009 at 11:57 am
    need a lot more info;
    1. The properties of your video clips…what is their source?
    2. Your system specs including drive configuration.
    Can you see images in the Source or Program monitors?
  • Mark Havens
    September 9, 2009 at 4:47 pm
    Here are the specs on the video:
    Type: H.264
    Image Size: 1920×1080
    Aspect Ratio: 16:9
    System Bitrate: 18.00 mbps
    Video Format: H.264
    Video Bitrate: 16.00 mbps
    Frame Rate: 29.97 fps
    I don’t know my system specs, but when I don’t have the video in premiere I can play it if that helps at all.
    I do know that my system sucks and I’m actually waiting for my new one to come in the mail.
