Activity Forums Apple Final Cut Pro Legacy I know I shouldn’t have upgraded to Quicktime 7!
  • I know I shouldn’t have upgraded to Quicktime 7!
    Posted by Michael Black on May 20, 2006 at 12:54 am
    This is exactly why I put this off for so long:
    I upgraded to Quicktime 7 and use the Kona2 card for capturing HD from a D5. Before, the easy setups were straightforward and simple. Now? not so much. When I select Uncompressed 10-Bit 23.98, the sequence preset doesn’t work with the capture preset. The capture preset is set to Uncompressed 10-Bit, but the sequence is AJA Kona 10-big RGB codec. I also have the option of Aja Kona 10-bit Log RGB and AJA Kona 2Vuy Codec. What are the differences between these and what should I be using?
    I’ll post this on the Kona forum as well. Anyone else have this issue when they upgraded?
    michaelblack
    Michael Black replied 20 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
