Activity Forums Apple Final Cut Pro Legacy I Inherited a Feature Documentary that keeps crashing! HELP!!!
  • I Inherited a Feature Documentary that keeps crashing! HELP!!!
    Posted by Danny O’malley on February 11, 2009 at 9:07 pm
    I’m editing a feature doc. I’ve only been working on it for 2 weeks. It’s all DV footage, and FCP runs fine when I’m editing HD projects and using large projects in After Effects. The old editor tried to make it sound like I didn’t have enough ram. I have 5gigs of Ram on an quad core system. Here’s the situations where it has crashed.
    It has crashed after a good deal of functioning fine, while editing a large 40+ minute timeline.
    It has crashed when I opened up the file on an external firewire 800 drive and on an internal drive. Both with lots of spare memory.
    It has crashed upon opening the project with all files disconnected.
    It has crashed with all the files connected to the files external hard drives.
    It has told me that the project was made by a newer version (of course I have the newest FCP),
    I’m assuming the project file is corrupted, because different drives, or disconnected footage doesn’t make a difference. I’ve tried saving as a new file. I’m trying to create a new project file at the moment. FCP runs smoothly with all other projects too.
    I’ve repaired disk permissions, and trashed the preferences multiple times. Deleted the renders, changed the scratch disks, ect?
    I may media manage the used footage into a new project if that works.
    Any other suggestions or ideas? I need this fixed ASAP.
    Crash report:
    System Configuration:
    Model: MacPro2,1, BootROM MP21.007F.B06, 8 processors, Quad-Core Intel Xeon, 3 GHz, 5 GB
    Graphics: kHW_ATIr580Item, ATY,RadeonX1900, spdisplays_pcie_device, 512 MB
    Memory Module: DIMM Riser A/DIMM 1, 2 GB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser A/DIMM 2, 2 GB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser B/DIMM 1, 512 MB, DDR2 FB-DIMM, 667 MHz
    Memory Module: DIMM Riser B/DIMM 2, 512 MB, DDR2 FB-DIMM, 667 MHz
    AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x87), Broadcom BCM43xx 1.0 (5.10.38.24)
    Bluetooth: Version 2.1.3f8, 2 service, 1 devices, 1 incoming serial ports
    Network Service: AirPort, AirPort, en2
    PCI Card: ATY,RadeonX1900, display, Slot-2
    Serial ATA Device: WDC WD2500AAJS-41RYA0, 232.89 GB
    Serial ATA Device: SAMSUNG HD753LJ, 698.64 GB
    Parallel ATA Device: OPTIARC DVD RW AD-7170A
    USB Device: hub_device, (null) mA
    USB Device: iLok, (null) mA
    USB Device: CTE-630-UV3.1-4, (null) mA
    USB Device: USB Uno MIDI Interface, (null) mA
    USB Device: Bluetooth USB Host Controller, (null) mA
    FireWire Device: built-in_hub, unknown_value, unknown_speed
    FireWire Device: Iomega eGo HDD, Iomega, 400mbit_speed
    FireWire Device: OneTouch, Maxtor, 400mbit_speed
    FireWire Device: Mbox 2 Pro, DIGIDESIGN, 400mbit_speed
    Problem Details:
    Process: Final Cut Pro [3040]
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Identifier: com.apple.FinalCutPro
    Version: 6.0.5 (6.0.5)
    Build Info: FCPApp-810171515~24
    Code Type: X86 (Native)
    Parent Process: launchd [159]
    Date/Time: 2009-02-11 13:18:54.087 -0800
    OS Version: Mac OS X 10.5.6 (9G55)
    Report Version: 6
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread: 0
    Thread 0 Crashed:
    0 …pple.ATIRadeonX1000GLDriver 0x09863f94 gldGetString + 110740
    1 …pple.ATIRadeonX1000GLDriver 0x098b7a82 gldGetString + 453506
    2 …pple.ATIRadeonX1000GLDriver 0x09830f84 gldInitDispatch + 12308
    3 …pple.ATIRadeonX1000GLDriver 0x09832485 gldInitDispatch + 17685
    4 …pple.ATIRadeonX1000GLDriver 0x09832bac gldInitDispatch + 19516
    5 …pple.ATIRadeonX1000GLDriver 0x09811056 gldGetPipelineProgramInfo + 38
    6 GLEngine 0x09668ad5 glGetProgramivARB_Exec + 1445
    7 libGL.dylib 0x94ad500d glGetProgramivARB + 45
    8 com.apple.motion.filters 0x30fb6830 Effect_CanUseFragmentProgram(char const*) + 166
    9 com.apple.motion.filters 0x30fab3ec -[Vignette initWithAPIManager:] + 76
    10 …uartzComposer.FxPlugWrapper 0x2ee94c12 0x2ee92000 + 11282
    11 com.apple.QuartzComposer 0x95c6b115 +[GFNode(Private) newWithIdentifier:] + 99
    12 com.apple.ProFX 0x00e1f1a6 -[PFXNodeManager nodeInstanceWithName:] + 74
    13 com.apple.FinalCutPro 0x004f4fd5 PatchForEffectDict + 281
    14 com.apple.FinalCutPro 0x004f5fe4 EffectGetQCPatch(KGDictInt*) + 180
    15 com.apple.FinalCutPro 0x004f6013 EffectGetFrameSequenceChangedProc(KGDictInt*) + 17
    16 com.apple.FinalCutPro 0x000916af KGClipItemSyncEffects_((anonymous namespace)::ClipItem const&) + 243
    17 com.apple.FinalCutPro 0x00091a03 pKGClipItemSyncEffects(KGDictInt*, KGDictInt*) + 39
    18 com.apple.FinalCutPro 0x000bfb10 SetupMaintenanceCore(KGDictInt*, KGMessageableRec**) + 1988
    19 com.apple.FinalCutPro 0x000bfe22 ClipMaintenancePropagater(long, long, KGDictInt*, void*) + 350
    Andre D’elena replied 17 years, 6 months ago 4 Members · 3 Replies
  • Ben Holmes
    February 11, 2009 at 10:24 pm
    I’d maybe suggest trashing the render files if you can – it could be an issue with those. Generally, projects that go bad stay bad – they’re not unstable, their unusable. This suggests you have an issue with the media connections to the project – which could be render files.
    Whatever the issue is, if you cannot revert to a stable and previously saved version, I’d get a new project up and running with the timeline copied across – assuming you can keep the project open to do this.
    I would be tempted to split the timeline into sections, just copy and pasting them into a fresh project with (say) 4 timelines. At the very least, this may help to isolate the problem.
    I’d also recommend 8Gb RAM in an 8-Core (2xQuad Core) machine, or at least symmetrical RAM on each riser as per Apple’s recommendation – but I doubt that is the specific problem here.
    Ben
    Ben
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
  • Victor Perez
    February 12, 2009 at 12:12 am
    Here is something that has saved me in the past. Especially when I receive a new project from another editor and my system runs fine, but then…..
    For some reason I have noticed render files appearing inside my FCP Applications folder. Where are your renders going? I am sure Apple would not recommend everyone just checking out what is in there so be careful checking it as such.
    go to.
    your Applications folder
    right click on the FCP icon and click on Show Package Contents
    double click on MacOS
    If there is a Render Files folder in there open it to see of there are some stray render files from your current project in there. If so, move them to the trash but don’t delete yet. Re-open FCP and see if your timeline works. If so Delete the Render Files from the trash.
    I currently edit around 2 30 minute effects heavy projects a month and numerous short form ones. When my system is misbehaving I delete prefs, repair permissions and check that folder in Applications>FCP. this makes my mac happy.
    good luck
    Victor
  • Andre D’elena
    February 12, 2009 at 10:19 pm
    Did you empty the trash after you deleted the render files?? I’ve been hosed like this. Trashed Prefs, change scratch disk etc…and it turned out to be bad render files that were still in my trash can. Just a thought.
    Andre
