Activity › Forums › Adobe Photoshop › I have two photo I would like to merge together. I have tried everything. I’m about to cry and pull hair out. My email address is rynobwr@gmail.com
  • I have two photo I would like to merge together. I have tried everything. I’m about to cry and pull hair out. My email address is rynobwr@gmail.com
    Posted by Bruce Anderson on May 31, 2013 at 5:14 pm
    I Also would like my picture in color. I have uploaded two files.
    Respectfully,
    Bruce Anderson
    Jeff Hinkle replied 13 years, 3 months ago 2 Members · 4 Replies
  • Jeff Hinkle
    May 31, 2013 at 5:30 pm
    You don’t really say HOW you want to merge the files. Are you trying to get the man to sit behind the desk? (The monitor will be blocking his face.) Is he supposed to be in front of the desk? Is he in the monitor?
    I will say this: based on the two photos’ wildly varying colors, quality, lighting, angles, etc. making them look like they are actually one photo is highly unlikely. Rather than beat your head against a wall for hours trying, I’d suggest you at least re-shoot your talent with a higher-quality camera, lit to match the scene you’re trying to place him in. Save yourself a lot of headaches.
    It is easier to destroy than to create.
    More fun, too.
  • Bruce Anderson
    June 1, 2013 at 12:35 am
    First of all thank you for responding.
    I will do a re-shoot with better camera.
    Yes I would like me (him) sitting behind the desk. But if he will be covered is there a way you can move the monitor?
    Thank you so so much! I will take the photo tomorrow in morning.
    Respectfully,
    Bruce
  • Bruce Anderson
    June 1, 2013 at 1:48 pm
    Respectfully,
    Bruce
    Here is a color photo of me also with the desk.
    Thanks allot,
    Bruce
  • Jeff Hinkle
    June 3, 2013 at 2:01 pm
    Bruce,
    You’re still facing the same issues with your talent photo: the lighting, angle, quality and colors don’t match at all. Using the built-in web cam on your computer, I’m guessing? Try using a better camera and have someone take the photo of you. Try to match the angle and lighting of your set photo.
    As for the monitor, you can probably cut that out to its own layer, slide it over, and use other parts of the image to paint in the hole it leaves, but it’ll take a bit of time to get it to look right.
    Good luck!
    More fun, too.
