Activity › Forums › Apple Final Cut Pro Legacy › I have no idea what the problem is
Posted by David Zietz on June 3, 2012 at 3:30 amRaw footage from shoot was 1080p. I found out there was a problem when I exported the footage to mov format for a colleague to apply effects in After Effects. When he put it up on a 1080 workspace, everything was pixellated and looked like crap. We went in and looked at the sequence settings and it says 720×480. We tried messing with the sequence settings, changing them to 1920×1080, but now the footage only occupies a very small space in the canvas. What the heck is going on and what do I need to do to get it into the right format?
David
David Zietz replied 14 years, 3 months ago 3 Members · 16 Replies -
Shane Ross
June 3, 2012 at 5:22 amHighlight all the footage. Right click and choose “remove attributes”. Choose Basic Motion and Distort.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Michael Gissing
June 3, 2012 at 5:32 amAlso make sure the sequence settings match the footage codec and frame rate. You might have multiple errors with the timeline.
If you create a new sequence and drag one shot into the timeline, FCP should prompt you to change sequence settings to match the clip settings. Say yes and then copy paste the old sequence into the new one. As Shane says, also remove all motion attributes like size and distort.
David Zietz
June 3, 2012 at 6:18 pmThanks for the reply! Basic motion and filters are the only choices available. Everything else is grayed out. Does that matter? Also, how will this impact the work that I’ve done already?
David
Shane Ross
June 3, 2012 at 7:32 pmThat’s fine that the other options are grey.
And if you did any push ins on footage, or repositioning, it’ll get undone when you do this.
Shane
Little Frog Post
David Zietz
June 3, 2012 at 7:45 pmOoh. That’s no good. Is there a way to get those back and still have the correct output?
David
David Zietz
June 3, 2012 at 7:48 pmThanks for the reply! I just pick one shot and then drop the whole timeline in a new sequence? They used two different cameras, so half of the clips are of different settings. How will that fact impact your suggestion, if at all?
David
Michael Gissing
June 3, 2012 at 10:04 pmWithout knowing what the two cameras were and the two codecs you are dealing with it is hard to offer advice.
David Zietz
June 8, 2012 at 4:00 pmSomething weird that I found. I went and followed with your suggestions, but the output was still stretched on the 1920×1080 workspace.
So I went back and checked the attributes of individual clips and found that they were all 1920×1080 with square pixels and no compression. I decided to check the overall sequence attributes and saw that they’re 720×480, with h.264 compression and the pixels are NTSC-ccir 601.
Why? Is this the source of my problem and how can I fix it?
David
David Zietz
June 8, 2012 at 4:04 pmNevermind, I saw what i was doing wrong. I got it. Thanks guys!
David
Shane Ross
June 8, 2012 at 4:26 pmYour SEQUENCE is 720×480 with an H.264 compressor? How the heck did that happen? Yeah, that’s a BIG problem.
[David Zietz] ” I went back and checked the attributes of individual clips and found that they were all 1920×1080 with square pixels and no compression”
Uh…what? The compressor is “None?” What codec is this footage? It really needs to be an editing codec, like ProRes. If it is NONE, that too is a huge issue.
The sequence settings should be ProRes 1920×1080 in the frame rate of the footage. And the footage should also be ProRes.
Shane
Little Frog Post
