Activity Forums Adobe After Effects I have a problem about loop and array
  • I have a problem about loop and array
    Posted by Supak Suksawat on October 15, 2021 at 7:02 am
    var layersList = app.project.activeItem.selectedLayers;
    var o=[layersList];
    for (i=0;i<layersList.length;i++){
    checkNAME[i]=layersList[i].name;
    checkNAME2[i]=layersList[i].name;
    index=checkNAME[i].lastIndexOf (“-“);
    if(index>=0){
    checkNAME[i]= checkNAME[i].substring (0, index);
    if(checkNAME2[i].indexOf(checkNAME[i])!==-1){
    if(checkNAME2[i].indexOf(“1”,index)>-1){ <—-1
    o[i]=layersList[i];
    for(i=0;i<layersList.length;i++){
    if(o[i]==null){
    continue;
    if(layersList[i].name==o[i].name){
    continue;
    alert(layersList[i].name);<—-2
    I try to use loop to collect layers to array of o and I want get the layer that have name like point 1 and put it and show the layer that not like 1 at 2 but it don’t show anything to me.
    such as, I have layer A 01-1, A 01-2, A 01-3, B 01-1, B 01-2, B 01-3, B 01-4
    It should be show A 01-2, A 01-3 and B 01-2, B 01-3, B 01-4
    Meng Zhiqun replied 4 years, 10 months ago 2 Members · 1 Reply
  • Meng Zhiqun
    October 30, 2021 at 1:08 pm
    I tried hard to understand what did you want to do with your script. With the best of my ability, I think what you need, is to get an array of layers that has a certain string in the layer’s name.
    Here’s a function you can use instead.
    var proj = app.project;
    var projComp = app.project.activeItem;
    var selLay = projComp.selectedLayers;
    function getLay(searchNameForthis){
    var getLay = [];
    for(var i = 0; i <= selLay.length-1; i++){
    var curLay = selLay[i];
    if(curLay.name.toLowerCase().indexOf(searchNameForthis) != -1){
    getLay.push(curLay);
    if(getLay.length > 0){
    return getLay;
    }else{
    return 0;
    alert(getLay("solid"));
    You can replace the “Solid” in getLay(“Solid”); with any string that you wish to find the names by and this function will give you the layers. Hope this helps.
