Activity Forums Apple Final Cut Pro Legacy I have a Decklink card. Do I need another, seperate audio card to use the VO tool?
  • I have a Decklink card. Do I need another, seperate audio card to use the VO tool?
    Posted by Ian Dillon on October 19, 2008 at 12:51 am
    I have a Decklink video card. Do I need another, seperate audio card to use the VO tool? I can’t seem to get the Decklink to record in VO Tool mode.
    John Fishback
    replied 17 years, 10 months ago
    4 Members · 3 Replies
  • Harry Bromley-davenport
    October 19, 2008 at 4:22 am
    You do not need any special card to run the V/O tool.
    Your signal should go from your mike, through a preamplifier (you could use a camera, for instance) and then into the line input on the rear of your Mac.
    If you connect the mike directly into the Mac, there won’t be a strong enough signal to register. This may be your problem.
    It’s a great tool and I use it all the time for ADR and foley.
    Harry
  • Russell Lasson
    October 19, 2008 at 4:52 am
    You might try sending a video signal to the video input. I don’t recall, but I was in a situation once where this helped. Any signal will work. Be interesting to see if it helps.
    -Russ
    Russell Lasson
    Ridgeline Digital Cinema Mastering
    Universal Post
    Salt Lake City, UT
  • John Fishback
    October 19, 2008 at 8:54 pm
    You can also use the optical input on a Mac if your mixer has an optical out. I’ve found that to be better quality than line input.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.4 QT7.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
