Activity Forums Adobe After Effects I have 4GB of RAM but AE says “2% used of 3GB”
  • I have 4GB of RAM but AE says “2% used of 3GB”
    Posted by Jordan Flower on August 18, 2008 at 5:46 pm
    When I open up AE, the start up window says “2% used of 3GB.” I am assuming this is referring to my memory, but I have 4GB of RAM installed. System Profiler would also confirm this. Does this mean AE is only using 3 out of 4GB of my memory?
    Kevin Camp replied 18 years ago 3 Members · 4 Replies
  • Peter Last
    August 18, 2008 at 6:36 pm
  • Kevin Camp
    August 19, 2008 at 5:00 pm
    if you are using a 64-bit windows and you have multiple processors (or cores) you can utilize all 4gb for rendering and previews if you enable multiprocessing in after effects (preferences>multiprocessing). this will launch multiple render engines (one for each processor) and allow each to utilize about 2gb of ram.
    if you are running 32-bit windows then the most your system can address is 4gb (1gb for system and 3gb for other applications).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Jordan Flower
    August 19, 2008 at 5:37 pm
    I am using Mac OS 10.4.11 Not sure if that changes anything.
  • Kevin Camp
    August 19, 2008 at 7:00 pm
    yep, that makes it easy…
    osx is 64-bit, so your system can address all the ram you can throw at it. ae (being 32-bit) is still limited to 3gb, but with multiprocessing the render engine can utilize around 2gb per core… so, if you have a 4-core mac, it could use around 8gb of ram for rendering with multiprocessing enabled.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
