Activity Forums Adobe After Effects I get this error “the file format module could not parse the file” 45::35 When i try to export in after effects
  • I get this error “the file format module could not parse the file” 45::35 When i try to export in after effects
    Posted by Ladorn45 on December 21, 2007 at 6:25 am
    Hey I keep getting this error when i try to export a project. The file format module could not parse the file”. I am not sure what i can do to solve this issue or why it is doing it. Does anyone know why this is doing it and what i can do to fix this problem. Thanks in advance
    Abhishek Gavi replied 11 years, 1 month ago 13 Members · 14 Replies
  • 14 Replies
  • Peter Van der zee
    December 21, 2007 at 9:59 am
    I know this message from wrong tiff or targa footage
    Saving the file in photoshop again, normaly does the trick.
    I only don’t understand why you say “exporting the project”
    Do you mean “render a movie”? (apple-m)
    vanderzee.tv
  • Ladorn45
    December 21, 2007 at 2:41 pm
    Sorry about that. That is what I meant to say. So if I save the original image as a .psd that should do the trick? Once again thank you for your help
  • Joseph Ahn
    June 12, 2008 at 9:22 pm
    is your source file a still frame or a sequence? i have sequence files getting the same error message. would you bring sequence files to photoshop and re-save it? what would be the work flow this? i would imagine you’d use the automatic feature in photoshop…
    i’d appreciate your feedback.
    j.
  • Rick Sullivan
    December 17, 2008 at 5:43 pm
    I’ve followed the guidelines listed in this post to no avail. Even after importing to Photoshop and re-saving a file as .TIF AND .JPG, my files will not import to AE. I’ve imported other .tif and .jpg to be sure they worked okay and they did. I don’t understand why I cannot get this logo to import? It was created on a MAC. I checked PC when I re-saved it. And I can also see it in the thumbnails just fine.
    Thanks for any suggestions,
    rick sullivan ricksullivan@nc.rr.com
    Rick Sullivan
    http://www.ricksullivanmedia.com
  • Naiche Lujan
    January 19, 2009 at 8:01 pm
    had exact same problem, file was cmyk, i changed it to rgb, and it imported like butter.
  • Kay Martin
    August 24, 2009 at 6:36 pm
    Dave,
    Thanks so much for this post, i’ve solved a few problems with your suggestions in the past on various topics!
    Kay
  • Andy Sapp
    May 6, 2011 at 6:51 pm
    I just got this error dealing with in iff sequence… and it turns out I had imported it off the server, and the sequence had not finished rendering all-the-way through.
  • Adriano Zanetti
    April 3, 2012 at 5:10 pm
    I’ve rendered a sequence out of 3ds max, saved the sequence as Tga, the beauty pass imports just fine, but the render elements passes (also Tga) do not import, i get that same error message “the file format module could not parse the file”.
    Also i notice that some files are still rendering in the same folder, an other sequence with different name, but output is the same folder, can it cause this sort of issues?
    Thanks for helping.
  • Micah Moore
    August 4, 2012 at 1:10 am
    Same thing happened to me.After effects gave me this error when importing a rendered image sequence of targas….
    Look at all your rendered images.Sort list by details and look at size.
    You’ll have some 0kb files.
    BAD FRAMES!
    Rerender those, replace them, reload image sequence in After Effects and you’re golden.
    -MM
  • Adriano Zanetti
    August 4, 2012 at 4:05 am
    ah yes, thanks for replying to the thread. I had figured out that much already but got caught up by work and forgot to post again. INdeed, there was a bad frame in the middle of teh sequence, what happened is that i got a power shut down and it stopped a render in the middle, the last frame that was being saved was not saved properly before the shut down, when i started it up again i started after he last frame without noticing it was messed up (0Kb). Took me quite some time to figure it out…. Grrrr… 🙂
    Cheers, dude.
    A.
