Activity Forums Adobe After Effects I get this error “the file format module could not parse the file” 45::35 When i try to import into after effects
  • I get this error “the file format module could not parse the file” 45::35 When i try to import into after effects
    Posted by Declan Power on October 18, 2009 at 8:52 am
    I get this error “the file format module could not parse the file” 45::35 When i try to import into after effects. I have changed images from CYMK to RGB, also tried convertig to tif and more formats. tested different files and they work perfectly so not machine or AE, using CS3.. any help would be greatly appreciated, looming deadline, dp
    D.Power
    EG Digital Productions.
    44 28 677 42828
    d.power@emerging-group.com
    Erik Waluska replied 14 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Erik Waluska
    October 18, 2009 at 3:53 pm
    Declan,
    A quick search for “could not parse the file” on the Cow forums turns up some nearly identical threads – all of which point to the file being CMYK instead of RGB. I know you said you converted it but…
    https://forums.creativecow.net/search.php?q=could+not+parse+the+file&f%5B%5D=2
    If that doesn’t help then please provide some information about the file you are trying to import.
    -E
  • Todd Kopriva
    October 18, 2009 at 5:12 pm
    Perhaps I’m beng dense and I missed it, but did you say what kind of file you’re trying to import?
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Declan Power
    October 18, 2009 at 7:02 pm
    Thanks for the help, i opened the images,saved them as rgb PSD’s and that worked.. dont know why this haooened, but this is a fix… thanks again..
    D.Power
    44 28 677 42828
  • Declan Power
    October 18, 2009 at 7:04 pm
    tif’s and JPEGS
    D.Power
    44 28 677 42828
  • David Cabestany
    March 20, 2012 at 3:06 am
    I’m getting this error too, except ALL my links are rgb, some always were, some I had to convert with photoshop.
    Why am I still getting the error?
  • Erik Waluska
    March 20, 2012 at 3:09 pm
    What type of files?
  • David Cabestany
    March 20, 2012 at 7:34 pm
    Jpgs, 8 bits.
  • Erik Waluska
    March 20, 2012 at 8:39 pm
    I don’t know why you would get that error with .jpg files if they are all RGB color mode. Could you post one of the images?
