Activity › Forums › Adobe Encore DVD › i get an “unknown error” every it’s about to burn the dvd.
  • i get an “unknown error” every it’s about to burn the dvd.
    Posted by Frugtved on January 8, 2006 at 10:10 am
    help i have build menu and all is working. My footage is trancoded and i can check the dvd i encore “Check Project” with no error.
    But every time i try to build a dvd i get an “unknown error” every it’s about to burn the dvd.
    David replied 20 years, 8 months ago 3 Members · 2 Replies
  • David Bispham
    January 10, 2006 at 9:30 pm
    I would assume some transcoded video files are trancoded at too high of a rate.
    I have seen this problem before.
    You might duplicate the project and transcode any suspect video files at a really low rate and see if you can get the program to “build”. You can do all this without actually burning the DVD.
  • David
    January 11, 2006 at 4:46 pm
    I’m having the same “Unknown Error (DVD Error -1)” problem, but according to the disc tab and the build disc window, the total size of my transcoded files are less than the disc’s capacity by at least 400MB. Is there another reason for this error?
