Activity Forums Adobe Media Encoder I-Frame only on XDCAMHD
  • I-Frame only on XDCAMHD
    Posted by James Ronan on September 12, 2017 at 4:07 pm
    Hey guys
    Hoping I’m posting in the right forum…
    I’m trying to export an advert for UK TV.
    They’re specifications are:
    Codec: MPEG-2
    Container: OP1a
    Profile / Level: MPEG-2 4:2:2 / High
    Video: 100Mb/s
    Audio: PCM 2ch 48kHz 24bit
    GOP Structure: I Frame only
    Upper Field First
    Chroma: 422
    Framerate: 25fps
    Dimensions: 1920x1080px
    File Extension: .mxf
    I am using the XDCAMHD50 PAL (4:2:2) which I think is right, but when supplied it failed because it was “long-GOP” and it needs to be “I-Frame”
    In this Codecs settings in Adobe Media Encoder under Advanced XDCAM Settings there are two check boxes:
    Force Fixed-length GOPs
    Force Closed GOPs
    Does anyone would know if having any of these checked would turn it to “I-Frame”
    And could anyone explain what they mean?
    Thanks a lot!
    James
    Pradip Patil replied 6 years, 8 months ago 3 Members · 2 Replies
  • Chris Wright
    September 13, 2017 at 7:26 am
    gop length is from I frame to I frame so if that is 1. it should be all i frames (fastest editing)
    closed is not using adjacent b frames.(somewhat fast editing)
    i would select both and then test with ffmpeg’s ffprobe
    ffprobe -show_frames videofilename.mp4 > outputfile.txt
    Then you just look for the pict_type entries, which will be either I, P, or B. B denotes a b-frame.
  • Pradip Patil
    January 18, 2020 at 2:52 pm
    Hi James,
    Did you find solution to this as I have received similar specs for a project. I tried what Chris Wright suggested but the file still shows as non I-frame in MediaInfo.
    Thanks.
