Activity Forums Compression Techniques I frame only MPEG2
  • I frame only MPEG2
    Posted by Brian Lynn on May 30, 2012 at 6:23 am
    I am using Adobe Media Encoder on Windows to encode MPEG2 videos.
    The encoder does not give a setting for either “I Frames” or “Keyframes” but rather M and N Frame controls along with Closed GOP settings.
    I would think settings of M Frames: 1, N Frames: 1, Closed GOP every: 1 would result in an all I-Frame encoding?
    Brian Lynn replied 14 years, 3 months ago 2 Members · 2 Replies
  • Ben Waggoner
    May 30, 2012 at 5:32 pm
    IIRC, M=P frame, and N=B frame. So you probably want both to be 0.
  • Brian Lynn
    May 30, 2012 at 6:37 pm
    There is no option for 0.
    Based on what I’ve read if I set my closed GOP to 1 that is the same as closing the GOP every frame which should result in an all I-Frame video…
    Are there any tools out there to that can analyze a video and tell me what kind of frame structure it has?
