Activity Forums Adobe Premiere Pro I-Frame Only MPEG-2 -or- Uncompressed 10-bit
  • I-Frame Only MPEG-2 -or- Uncompressed 10-bit
    Posted by Kevindv on November 26, 2006 at 5:40 pm
    I have a Canon XH A1 HDV Camcorder and when I start and new project and go into the project settings under ‘Video Rendering’ and look at the options for File Format… I have a couple options listed to choose from:
    1) I-Frame Only MPEG-2
    2) Uncompressed 10-bit (4:2:2 YUV)
    3) Adobe Wavelet Codec
    I use Firewire to transfer the video from my camcorder to Premiere Pro using PP’s capture. I have had it set on ‘I-Frame Only MPEG-2’… would I be better off using the ‘Uncompressed 10-bit’ option? Would this give me greater color details, etc?
    Could someone kindly explain which one would give the best results (sharpest image) and what the advantages/disadvantages of these options are for HDV? Thanks for your help and time.
    Tim Kolb replied 19 years, 10 months ago 3 Members · 2 Replies
  • Mike Velte
    November 27, 2006 at 12:19 pm
    When creating a new project, I have 2 HDV options on the General page; HDV 720 and HDV 1080i, but no choices for the File format on the Video Rendering page, I-frame only Mpeg 2 is greyed out. If you shot in the HDV mode, choose one of the HDV presets that matches your camera setting…720 or 1080i.
    HDV is basically Mpeg2 I frame only on the DV tape which is then converted to an intermediate codec for editing.
  • Tim Kolb
    November 27, 2006 at 4:22 pm
    [mike velte] “HDV is basically Mpeg2 I frame only on the DV tape”
    Mike is right, HDV is MPEG2, but I-frame only would indicate that every frame is independently decodable like MJPEG.
    HDV is long GOP MPEG2 on tape…JVC’s GOP is 6 frames (HDV1) and Sony/Canon (HDV2) is either 12 frames (for 25fps) or 15 frames (30fps) and the GOP frame order is pretty standard “IBBPBBPBBPBBPBBIBBPBBP….” with an I frame starting each GOP.
    …small clarification.
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
