I finally got this DNxHD stuff sorted out
A while back I downloaded the Avid codecs to my PC and tried several times to export a DNxHD file from Premiere Pro, with no success. I mentioned it on the Premiere forum and no one knew what was wrong. Every time I tried to export, the media encoder immediately stopped, and a yellow triangle with an exclamation point appeared. It was really puzzling and frustrating, and left me feeling a bit bummed out. I knew being able to export to DNxHD would help a lot- especially for bringing stuff back to Premiere after doing things in After Effects.
While reading and watching videos about the improvements in the new versions of Premiere and AE, I remember seeing a lot about how more formats have the “match sequence settings” option available in the media encoder- and also seeing comments about how more formats still need to be supported. I remember someone saying that the ones that have it now are delivery formats, like H264, and it really needs to be added to things like ProRes and DNxHD as well, so we don’t have to go through and change every setting before we export them.
That got me thinking about working with DNxHD again, and made me think that maybe there was a setting somewhere that I missed when I did the export. I went back and tried it again, and sure enough, I saw a lot of stuff that could have led to the failed encodes that I did before. When I set the output format to quicktime, the default format that appeared first was a DV codec. When I changed it to DNxHD, all the output settings were still set for the DV codec that first appeared.
I remember seeing this when I first did it, and going through and changing things, but I’m guessing I overlooked a few things because I figured they would be set right already since the whole codec setting had been changed. But this time I went through the whole thing really well, and made sure I got everything matching, and lo and behold- it worked.
I’m really glad I got that figured out, because I can really see it coming in handy- especially for AE workflows.
______________________________________________
“Up until here, we still have enough track to stop the locomotive before it plunges into the ravine… But after this windmill it’s the future or bust.”
