Activity Forums Apple Final Cut Pro Legacy I created an Alfa but it just won’t key
  • I created an Alfa but it just won’t key
    Posted by Roy Schneider on June 1, 2005 at 1:41 am
    Hi All:
    I have a question about keying with an alfa. I created a lower third in photo shop, and made an alfa channel for it. I saved the flattened layers with the alfa. I then imported the graphic into Final Cut pro. I put it on the top layer, but the key was not cutting. Can someone guide me through the process of keying with an alfa, as well as getting the graphic to look it’s crispest.
    Thanks for your input.
    Long Live the Cow!
    Roy
    Tony replied 21 years, 3 months ago 3 Members · 2 Replies
  • Bouncing Account needs new email address
    June 1, 2005 at 12:07 pm
    Click the graphic into the Viewer (left) Window. Then:
    Modify (menu) > Alpha Type > Straight
    If the key is “inverted” you may need to choose:
    Modify (menu) > Reverse Alpha
  • Tony
    June 1, 2005 at 4:40 pm
    Roy,
    FYI it actually spelled and called an Alpha channel.
    Tony Salgado
