Activity Forums Adobe Encore DVD I can’t successful install Encore CS3.
  • I can’t successful install Encore CS3.
    Posted by Blue99 on August 14, 2007 at 2:55 am
    I use the tryout version of Adobe CS3 Master Collection before.
    Now, I install Encore again and want to activate it.
    But, when I open Encore after install Adobe CS3 Master Collection again. It will auto close it.
    I can’t input the activate code.
    Can you tell me the problems?
    Blue99 replied 19 years, 1 month ago 2 Members · 2 Replies
  • Jerry Black
    August 14, 2007 at 6:53 pm
    It could be a number of different things in addiion to whether you are using a MAC or PC environment. If you loaded a trial version then did not purchase it or decided to take another route, you will have to completely reomove the original trial version. Assuming this is a PC platform, you will need to get the Adobe Script removal tool from Adobe (free) and follow the instructions carefully, including a second step that involves using the Microsoft deep removal tool which will remove any traces of the former progarm so that you are sure that you are working with a clean install.
    Follow the instructions for both the Adobe Script removal and the Microsoft file removal tool very carefully as there is NO return if you are not careful. I experience a similar situation and this worked perfectly!
    Good luck.
  • Blue99
    August 16, 2007 at 6:12 am
    Really thanks a lot! I will try to do it.
    I think I haven’t full clean it.
