Activity › Forums › Maxon Cinema 4D › I can’t see objects in the object manager window?
Posted by Joey Deutsch on November 5, 2013 at 4:50 pmI tried restarting and resetting my layout, but nothing will show! I am on Studio R12.
Sathish Ak replied 10 years ago 7 Members · 8 Replies -
Adam Trachtenberg
November 5, 2013 at 5:10 pmHave you messed around with the filters? Click the eye icon at the top right of the OM and make sure all the layers are turned on.
Joey Deutsch
November 5, 2013 at 5:18 pmYup, I have one layer and it is on. I still don’t see anything.
Adam Trachtenberg
November 6, 2013 at 3:54 pmNot sure what’s going on there. You might need to trash your prefs folder and start fresh.
Chad Wixom
December 6, 2013 at 3:57 amI’m having this same issue. I go to render view and it appears. So basically. Default startup (just installed) and I created a Torus. Nothing but points and lines. No object appears on the workplane (Even that was disabled upon startup). I have even tried opening a project and still the same issue. Driving me nuts.
This is a fresh install Demo of R15.
Tim Pfeiffer
September 26, 2014 at 3:23 pmI’m having the exact same issue with the Object Manager. I tried all the different View settings but nothing is coming back. Blank OM. Even if I create a simple cube it doesn’t show up in the object Manager. Did you ever figure this out? Can you help me?
Marta Breijo
February 1, 2016 at 4:34 pmOk this worked for me. I obviously touched something I shouldn’t 😛
