I can’t save my coloring! Why?
Posted by Serena Profilato on March 9, 2011 at 1:21 pmRecently I did a disk cleanup on my computer to remove the unnecessary programs, but this shouldn’t affect sony vegas.
Now, I don’t know why, I can’t save the coloring and I need some help to fix this problem!!
Maybe I accidentally delete a folder??
Please help!!Dylan Henry replied 15 years, 6 months ago 3 Members · 5 Replies -
John Rofrano
March 9, 2011 at 1:47 pm[serena profilato] “Recently I did a disk cleanup on my computer to remove the unnecessary programs, but this shouldn’t affect sony vegas.”
How did you do the “clean up”? Did you use a registry cleaner or other program? These are very dangerous to use.
[serena profilato] “Now, I don’t know why, I can’t save the coloring and I need some help to fix this problem!!”
I don’t know what you are talking about. Can you use Vegas terminology to explain what it is you are trying to do / save? Are these FX chains? Presets?, ???
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Serena Profilato
March 9, 2011 at 2:13 pmOk sorry but I’m Italian and it’s hard for me to explain that with vegas terminology, let’s try..
I go to Video Track FX
I create the coloring that I want to using with the FX
Then I can save it choosing Save As..
Then I’ve to put the name that I want and then Ok.
But actually sony vegas don’t save it, because when I go to Filter Packages there isn’t the coloring that I have saved..
Instead sometimes it saves the coloring that I made for three or four time but only one of them works (the original I suppose), the other don’t work and they can’t be delete.. -
John Rofrano
March 9, 2011 at 3:12 pm[serena profilato] “Ok sorry but I’m Italian and it’s hard for me to explain that with vegas terminology, let’s try..”
OK, now I’m jealous because I’m Italian too but I can’t speak a word of Italian because my parents wouldn’t teach me so that they could talk Italian in front of us kids and we wouldn’t know what they were saying. It probably also had something to do with them wanting us to “assimilate” into the American culture but I still regret never having learned the language. (but I digress…) 😉
[serena profilato] “I go to Video Track FX
Then I’ve to put the name that I want and then Ok.”That’s what I thought you were doing. These Filter Paclages are what I called “FX Chains”. These are stored in the Windows registry. That’s why I asked how you cleaned up your other applications. If you used a registry cleaner it may have messed this up.
I don’t know if you are comfortable editing the registry but the Filter Packages are kept in the following location:
HKEY_CURRENT_USER\Software\DirectShow\Presets\FX Packages\
If there any software on your PC that would limit access to the registry and prevent Vegas from saving these?
You might want to simply re-install Vegas and see if it re-establishes all of this for you.
~jr
Serena Profilato
March 9, 2011 at 5:19 pmIn this moment if you knew my language everything would be much easier for me haha!
Anyways with the help of internet I’m trying to editing the registry.
I’ll see what will come out!
Thank you very much for now!! -
Dylan Henry
March 14, 2011 at 11:32 pmThe solution (At last): Make sure your account your using on your computer is an administrator, and right click on the sony vegas pro 10 icon, and select run as administrator, to diable this from hapenning, turn off UAC (User Account Control)
